Break-in Dutch
i saw something interesting from redrc, the break-in device is having the whole engine soaked with fluid with temperature and the shaft connected with a motor, computer controls rpm and probably temperature.
i just wonder how would the burr go away without scratching(staying) inside the engine.
http://www.redrc.net/2015/03/break-i...od/#more-93745
Heatcyle is a way but not needed. I only would advise when going to the track to do 1 or 2 tanks carefully because when the piston is realy heating up by the combustions there could be some grow in the piston.
A simplified version of this method was developed by one of the Grand Rapids dirt oval racers about 5 years ago , I have used the simplified method on and off to some degree of success over this time period but it does not complete the process , I've found you still need some track run-in to completely get a motor ready to race.
Another vid tells it can handle up to 200 degrees.
https://www.youtube.com/watch?v=J3k4...ature=youtu.be
Because no fuel is needed and no high rpm is used you can think op any type of oil from simple 5W40 car oil up to high racing oils or even hone oil.
1Likes
