STS .28 pull-start engine
Old 02-26-2006 | 11:21 AM
  #451
tg
Originally Posted by ryan6682
you have a pm
pm?
tg is offline
Old 02-26-2006 | 12:48 PM
  #452
pino's Avatar
Originally Posted by tg
pm?
PM = Private Message
pino is offline
Old 02-26-2006 | 01:54 PM
  #453
Thumbs up
Hi Ryan can I ask where you are? and do you sell these engines? thank you
matt1_74 is offline
Old 02-26-2006 | 07:21 PM
  #454
ryan6682's Avatar
Utah
yea I handle the sales and service for www.racernine.com
ryan6682 is offline
Old 02-26-2006 | 10:38 PM
  #455
Hello people. After reading alot of this thread i bought an sts .28 as my nitrostar 25 crank case SNAPPED on a heavy impact landing up the wronge way on concrete. Today i have been running it in and am very impressed, but i have a big problem. The thread for the glow plug has stripped with little force tightening the plug and now i have fuel pissing out when it is running. Can anyone tell me if i have to get another sts button or will another make fit. As you can imagine it has fustrated me and i dont know where to get sts parts. Any advise will be much appreciated. Thanks.
I've had this happen to me yesterday during breakin, turns out that the thread on the plug was messed up. I used a new plug and all was good again.
crunch123 is offline
Old 03-01-2006 | 07:10 AM
  #456
HI Dino!!
Please let me know if you check my engine and what happend
Edgar
Puerto Rico
Edgar Millenium is offline
Old 03-14-2006 | 10:50 PM
  #457
Thunder racer's Avatar
hi all
thinking about buying a sts 28 for my HPI savage. Good idea? will it be much faster then my k4.6? is a bolt stagiht in or will i have to mod?
cheers
Thunder racer is offline
Old 03-15-2006 | 04:19 AM
  #458
ryan6682's Avatar
yes it will bolt right in and it has lots more power than the k4 motor.
ryan6682 is offline
Old 03-15-2006 | 06:43 PM
  #459
jfc_tech's Avatar
i second that and much much more that the K4. get ready yer 5th wheel or yer Savage X style head protector!!!!
for me...just gear up..use 47 spur with 19CB.
jfc_tech is offline
Old 03-15-2006 | 08:34 PM
  #460
ozpall's Avatar
x3 here.
I'm running 47/18
this motor is awesome!!!
anybody knows between the sts 28 and the surefire .32 which one would be faster?
I just read the article in an rc magazine about the sure fire but they said it only puts out 2.8hp not the 3.6hp that the company claims?
ozpall is offline
Old 03-19-2006 | 05:11 PM
  #461
Hey Good people!
I have a question for ya's, a couple of weeks back I sat down and read this thread and others from start to finish taking notes here and there, I noted and from memory it was Dino that wrote his LSN was approx 4 turns out and his HSN was approx 1.5 - 2 turns out. Is this correct?
If so, can you tell me if the top of the LSN is pretty much flush with the brass bit (#21050B)?
I ask as up until now the LSN has been way further out than it is now and my HSN has also been way further out that it is now. I am not sure whether these settings are safe to try!
matt1_74 is offline
Old 03-19-2006 | 05:39 PM
  #462
ryan6682's Avatar
well thats how his was tuned for his altitude and climate.
you las generally ends up being somewhere close to flush. the hsn usually ends up down inside and not flush with the top of the fitting
ryan6682 is offline
Old 03-19-2006 | 06:12 PM
  #463
ozpall's Avatar
Hey Good people!
yeah it all depends where you live, what kind of car are you running this engine ine? savage? buggy?
my LSN sticks out quite a bit, not sure how many turns i have since i just run my truck and listen to it to see how is running if it needs to be reachen or lean out and then check tempatures. so i don't keep count on turns anymore.
ozpall is offline
Old 03-19-2006 | 08:21 PM
  #464
Oh sorry, I am running it in a savage LE 3-spd 19/47 CB/SG.... anything less left me lying upside down.... but I have noticed my carb leaking so I have just sealed that also.... I shall try it later and monitor temps etc
matt1_74 is offline
Old 03-22-2006 | 11:30 PM
  #465
Marco.Frentzen's Avatar
Default Glow plug!
Hy gents! I have a question about glow plugs for the .28STS engine. I drive a LST and due to the fact that my Mach.26 engine is quit damaged i will use my new STS one. burn in is quite OK and I understand the procedure - but which type of glow plug I should use for this STS? And - what is the recommended cooling head temperature during normal run. Here in germany the averrage temperature is about 20-25°C.
OK - thats it for today!
Marco.Frentzen is offline
