Old 01-17-2011, 02:20 PM   #16
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by eldwin65 View Post
ok guys, so wats the conclusion??? ceremic bearing needs warm up??? if yes, for how long??? 2 laps??? 1 lap???? still must thank all of your valuable info... tks guys
just for ease of mind bench warm the engine & take a couple of soft laps & you should be good
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is online now   Reply With Quote
Old 01-17-2011, 02:22 PM   #17
GMartinez's Avatar
The fresh fuel going through the crankshaft keeps it quite cool downstairs in the engine, if you do pre heat the engine it should be warm enough for the bearings.
+1 Roe
Old 01-17-2011, 05:20 PM   #18
exactly, no engine likes to run crazy while it's cold. Ceramic or not, it has to be ready to go all out otherwise problems will come up either during the race, or just later in it's life faster than it should.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 01-17-2011, 07:15 PM   #19
West03's Avatar
Originally Posted by DJ_Shakespear View Post
What Im saying, at least I think Im trying to say, is that in a ceramic VS steel bearing scenario, the ceramic does not need lubrication in the fuel to get it to perform well - they go all out no matter what, whereas the steel bearing needs a bit of lube and heat to get it to be at its best inside an engine.
I need further clarification, is it correct that if you use ceramic bearings then you don't have to run oil in the fuel because the bearings does not need lubrication?
EGA . MUGEN SEIKI (MRX5 WC) . MMI . SANWA . MURNAN MODIFIED
MRCCR - MELBOURNE RADIO CONTROL CIRCUIT RACING
www.mrccr.com.au
West03 is offline   Reply With Quote
Old 01-17-2011, 09:59 PM   #20
rias5037's Avatar
I have a Max .12 MF with ceramics, we run 16% for clubs and nationals here, the engine has done about 3.5 litres of fuel, never had to change the bearings, just the conrod and the wrist pin, i do however after every meet put about 2-4 drops on after-run oil in the engine and drop in the carb and turn the flywheel by hand a couple of times.
If you dont overheat the engine, all the internals, bearing included will last alot longer, 3.5lts on the same bearing and they are as good as new.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 01-17-2011, 10:12 PM   #21
No, that would be incorrect.
Ceramic bearings do require lubrication to keep things working, but unlike steel bearings they operate under less frictional force and don't generate as much heat as steel bearings. That's why they can run using less lubrication. You still need oil in the fuel to cool the engine (to a point) and so the other parts like the rod and pin areas can still be functional and not fail!
This is what I've read somewhere on the Boca Bearings site I believe, so if they are wrong, then I would be too considering I got this information from them.
So if somebody actually knows and can confirm what they say, just tell me - that's how people learn better. Not by basically screaming at them
Old 01-17-2011, 11:56 PM   #22
Roelof's Avatar
Send a message via ICQ to Roelof
It is not about needing less lubrication the whole time. At higher RPM's you do come to a limit that lubrication does not work well. We do reach that every time on the straight. Low friction materials like DLC coatings and ceramic may run on low lubrication for a short moment without damaging instantly.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-18-2011, 05:23 PM   #23
Correct. But I dont think that lubrication becomes much of a problem once you start reaching the 42,000 RPM mark, hardly any engine no matter what brand doesn't see that much RPM very often. And if it does, that would most likely be it's peak on a track IMO.
In a ceramic Vs steel comparison, under the same RPM and load circumstance, the ceramic bearing does not generate as much heat caused by the load and the friction of the balls and races as it rotates compared to a steel bearing.
Ceramic materials have a much lower coefficient of friction, which means that with the same surface contact area a steel bearing has as well, the amount of friction is a lot less in the Ceramic, so with that you get a more free spinning bearing that essentially runs cooler and can spin faster and easier then the highest quality steel bearing, unless its a poorly made ceramic Vs a Swiss "ABEC 10" steel bearing!! Plus the ceramic material is a lot lighter than steel materials which adds to reduced rotating mass!
Old 01-18-2011, 07:55 PM   #24
Default Food for thought
Something just to think about, the higher the rpm the more fuel you run, which in turn means more oil thru the motor.
Most bearing in motors are not ceramic they are only a hybrid steel case with ceramic balls.
Lubricant oil is also friction (drag on the engine internals)
fairgo is offline   Reply With Quote
Old 01-18-2011, 09:33 PM   #25
True, but if you think about it, the HSN is supposed to keep the flow constant mor-or-less, so you're right in saying more fuel is going through per second, but not per revolution, if you get what I mean.
Old 01-19-2011, 12:28 AM   #26
Roelof's Avatar
True but the raised heat is affecting the viscosity and working of the oil. More rpm does also mean more strokes so per stroke it does not use more fuel/oil, maybe even less......
Old 01-19-2011, 12:58 AM   #27
This is anal.
It is common sense to warm your engine before hard usage whatever bearings you use.
If the bearings are fcuked after a couple of gallons then replace them, ceramic or not. Chances are you would want a new engine by then anyway.
JIM1 is offline   Reply With Quote
Old 01-19-2011, 02:25 AM   #28
Roelof's Avatar
The main issue is that the Novarossi bearings aren't that what they supposed to be, a 5 liter of use maximum is becomming quite normal. Drivers are searching for a reason and do look it in their use and fuels while the bearings are just crap.
Old 01-19-2011, 03:26 AM   #29
Yes, you definitely have to warm up the engine to operating temps no matter how good the engine is. Its just how it all works. Ceramic or not, the engine runs differently when its cold compared to normal temps.
Old 01-19-2011, 03:38 AM   #30
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i didnt mind the blue ceramic balls of novarossi a couple of years ago. since they have gone to the black ones, had nothing but problems.
generally i will run in the motor , use it a couple of round days, then replace to steel bearing. they seem to last longer. and i dont really see a huge performance loss from it
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
anyone here got an SH Engine Pro 21 Onroad With Handmade Crankshaft/Ceramic Piston kyoshoevolvam3 Nitro On-Road 8 12-04-2010 09:34 AM
Nova rossi Toro Nero...FMS r1harper Nitro Off-Road 85 01-21-2010 01:26 PM
Front Bearing in Nova rossi losiracer78 Nitro Off-Road 9 02-08-2009 09:52 AM
