TURBO VS STANDARD GLOW PLUGS
Price:
Not really, cheap plugs are cheaper not matter what kind they are. OD turbos are cheap, GRP standards are expensive. You just see a lot more cheap standards than you do cheap turbos.
A good turbo of the right type in a well tuned motor will last longer. So what's cheaper: a $5 plug that lasts 4 tanks or an $11 plug that lasts over a gallon?
The turbo plug has a better sealing and falls in a perfect shape with the combustion room giving the best compression without distortion of the flow of the mixture. If it does something compared with standard plugs is maybe hard to tell, the change to give it a try can alway give a different compression due the shape and tolerances of the new button head.
I know my 1st TOP engine with (by then) the new turbo plug did give me a lot of problems so I did use a button head of an old engine and normal plugs and did not notice anything but only a better life of the plugs (back in 1994). Today there is no one with an high end top engine even wanting to try a standard plug....
Turbo plugs are patented, that will make a difference in price. Also the shape between brands is not universal to go arround the patent so there is a less choice of plugs compared with the standard plugs which do have more choice in temp range but also more brands making them.
More R/C HYPE
In theory the more pent roof/shape charge effect= more HP, but in reality as far as
r/c engines, I can't find a differents. I went from standard to turbo in my Nova
367 and losted alot of bottom-end. I went from turbo to standard in my Nova FMS to lower the cooling head and lost no noticeable power. I know turbo plug engines are harder to tune, so that should give you a good indication on how efficient it's combustion chamber is. Just my $.02
More R/C HYPE
better, but it was running alittle hot and I think a hotter plug would have made it run too hot. Mostly all todays off-road engines are turbo. I think I seen a dyno test awhile back in a R/C magazine turbo v standard showing a very very slight HP gain in the very extreme top-end, but a slight mid- range lose.
so i have a first gen RB S3 in my sportwerks turmoil it was used about 2 gallons ran thru it and it had a standard plug in it what would da gains be if i switched to a turbo plug or should it have a turbo plug anyways
