OS TR engine thread
Old 06-03-2004 | 12:53 PM
  #76
ATOMIC's Avatar
Well as far as specs go I am not sure what they are but I do know that the engine is awsome. Rick Vessel was running a box stock and was as fast as 95% of the other engines. My engine had some crank work done on it and I was never passed on the straight and had more infield grunt than the track could handle. The most impressive thing to me was that putting the modified crank in did not change the way the engine wanted to idle . The engine was perfect, it would run for 8 minutes at 214 degrees. The outside temp was 90-100 degrees . Also remember that specs don't really mean much unless compairing them with the same manufactuer. My crank had some work but look at it like this, 159.00 for the engine (120.00 less than an x12) , so once you have it modified (100.00) , it is still cheaper , just as fast if not faster , and has the best carberator on the market(reliability). If anyone would like work on their engines , let me know and my guy will do them for 100.00. you can contact me at [email protected].
ATOMIC is offline
Old 06-03-2004 | 12:58 PM
  #77
ATOMIC's Avatar
By the way , gijoe64 did not know I was running a mod crank. I have not sent in my race report yet .
ATOMIC is offline
Old 06-03-2004 | 01:08 PM
  #78
gijoe64's Avatar
Thanks for the infor RON.
gijoe64 is offline
Old 06-03-2004 | 01:13 PM
  #79
jrabbito's Avatar
Thanks Atomic,
What type of work is done to the crank? Nice to see O.S. have an engine able to compete with the Italians. I currently have the 12 TR Turbo. Quite nice but not ROAR legal.
I await the release of this new engine....
thanks,
john
jrabbito is offline
Old 06-03-2004 | 01:31 PM
  #80
ATOMIC's Avatar
The timing had been opened up , thats about it. The center bore on the tr and r-spec are already at limit .
ATOMIC is offline
Old 06-03-2004 | 01:38 PM
  #81
Marcos.J's Avatar
Super Moderator
cool
Marcos.J is offline
Old 06-03-2004 | 02:47 PM
  #82
compaq888's Avatar
Originally posted by gijoe64
Spec: 4,000-36,000 RPM 1.5ps/31,000rpm
I don't want to be flamed for this, but i want to explain it for the noobs. 31,000rpms is when this engine makes the most power, but it goes up to 36000rpm, but at 36000rpm it won't make as much power. To have this engine be successful you would definetly need to have better gearing. That way you can keep up and even beat the Italian mills.
Am I right about the most power part gijoe64?
compaq888 is offline
Old 06-03-2004 | 03:01 PM
  #83
mckrooz's Avatar
But you would still need to have the rpms to pull that high gearing. Looks like this motor would be an excellent medium-large track motor.
mckrooz is offline
Old 06-03-2004 | 04:01 PM
  #84
Data's Avatar
Originally posted by mckrooz
I may have to watch Mikes daughter sat for a few hrs while he's working so I might not be there Don't have to watch her in the morning. Don't have to watch her at night. But from 11:30-4, THE PRIME HRS TO RACE AT THE TRACK!!!! Shoulda told them i was working too!
bring her to the track too, we will have eddie do baby sitting.
Data is offline
Old 06-03-2004 | 04:18 PM
  #85
mckrooz's Avatar
Uh oh Is that something that we wanna do?
mckrooz is offline
Old 06-03-2004 | 04:26 PM
  #86
Ah10's Avatar
Oh yeah since he spend most of the time setting up the car at the track anyway! may be he can bring a portable TV and put Barney tape in there too!
Ah10 is offline
  #87
Data's Avatar
eddie is a push over, she will be fine
Data is offline
Old 06-03-2004 | 04:27 PM
  #88
Data's Avatar
sorry, no barney please
Data is offline
Old 06-03-2004 | 04:30 PM
  #89
Data's Avatar
oh, i meant eddie will be safe
Data is offline
Old 06-03-2004 | 04:32 PM
  #90
compaq888's Avatar
that's sad
eddie is the guy with the RR evo??
