OS TR engine thread
Old 01-19-2005 | 06:21 PM
  #466
BrainTeased's Avatar
the kawahara heads fit straight over the turbo button. So no you dont need extra accessories.
BrainTeased is offline
Old 01-24-2005 | 02:12 AM
  #467
rcabj's Avatar
Default engine updates
well , following several of my posting on this engine...yesterday was it first test on a race after break in...
it felt slightly slow taking off (i guess my fault cause the low end not lean enough and also the wrong pipe combo) but the mid and top speed was excellent...
also in the 30 minutes main no engine cut off whatsoever.....overall i'm quite satisfied...
so future race gotta lean more the low needle...
thanks
rcabj is offline
Old 01-25-2005 | 12:08 AM
  #468
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by nsxshogun
Anyone have a baseline needle settings? I need something to follow to make sure mine is somewhere in the ball park.
for my ostr turbo engine, here are my settings...
high end needle: 1 3/4 from close
low end needle: 1 1/2 from close
middle needle: 1 full turn from flushed position from the carb
with this setting, my engine run at around 9mins for a 75cc tank and 230F temperature rating. engine is a bit on the rich side
hope this helps
doki_doki is offline
Old 01-25-2005 | 12:11 AM
  #469
doki_doki's Avatar
Originally posted by BrainTeased
http://www.rcaddict.com.au/product_i...roducts_id/126 this is what the kawahara heads look like for the OS TR nice novarossi purple color!
what i'm using is a zac silver anodized big engine head for my ostr turbo engine. it works great without any modification
Old 01-25-2005 | 12:12 AM
  #470
doki_doki's Avatar
Default glow plugs
i've tried using a rb plug #5 on my ostr turbo engine. it works great. no problems so far. the os turbo plugs are way to expensive...
Old 01-25-2005 | 04:57 PM
  #471
edracer1's Avatar
Yet another needle setting for the O.S. .12 TR (P)-T R-Spec.
High side needle 1 1/4 out from closed.
Low side needle 2 3/4 out from closed.
(Middle is per instructions 1 1/2 in from flush with the carb body).
All these settings are after break in. I also can get over nine min of race time at about 218 deg. But I intend to try the other settings listed. Just to see what difference they make.
edracer1 is offline
Old 01-25-2005 | 07:54 PM
  #472
rcabj's Avatar
9 minutes haaa...i must try that...very great advantage in long mains...cuts refueling time as long as no overheating occurs
rcabj is offline
Old 01-25-2005 | 08:31 PM
  #473
edracer1's Avatar
Yea, I kept thinking something must be wrong with my engine, until another racer who runs the exact same engine said he got 9:45 min run time. But I really haven't tuned it to race and just now will run my Logics turbo II pipe and this is the stock gearing not the .08... I'm sure it won't last.
edracer1 is offline
Old 01-26-2005 | 01:18 AM
  #474
rcabj's Avatar
i'm on the verge of getting me the rd logics turbo II, so how do u find this combo with the ostr??
rcabj is offline
Old 01-26-2005 | 07:24 AM
  #475
Hello,
Where can I find this engine to purchase?
on Tower Hobbies it says its discontuniued, however I beleive rc-car action did a review of this engine I think in its december issue if i'm not mistaken.
I have an os TR that i bought two years ago and I loved this engine for how easy it is to tune and its reliability.
Thanks for any help!
Atom
Atom is offline
Old 01-26-2005 | 10:34 AM
  #476
Marcos.J's Avatar
Super Moderator
Originally posted by Atom
Hello,
Atom
you can contact Tower Hobbies via telephone at 800-637-6050 (toll-free in the US or Canada)
Marcos.J is offline
Old 01-26-2005 | 12:14 PM
  #477
nsxshogun's Avatar
The rd logics pipes are very nice I have one for my r40.
nsxshogun is offline
Old 01-26-2005 | 12:31 PM
  #478
Marcos.J's Avatar
Super Moderator
You should try Skyline they are great products,and alot better priced here is my FW-05R with the VR12s pipe,
Marcos.J is offline
Old 01-28-2005 | 03:51 AM
  #479
doki_doki's Avatar
will also try your settings
Old 01-28-2005 | 03:53 AM
  #480
doki_doki's Avatar
Default tuning....
guys: which is better in tuning an engine??? tuning the leaning out the high end needle and richen the low end needle or the other way around???
thanks
