OS TR engine thread
Old 01-10-2005 | 01:53 AM
  #451
BrainTeased's Avatar
good stuff man! and remember dont use nova plugs you could get a possible air leak or damage your turbo button!
but have you also thought about a bigger head? those stock os tr heads are ugly and small!!!
i got myself a carlson 11 fin head works and looks a treat
also theres the kawahara head for it as well.
OS hyper heads are expensive so stay away from them.
BrainTeased is offline
Old 01-10-2005 | 02:08 AM
  #452
rcabj's Avatar
hello and thanks brain
i think its not that ugly
but i have thought about getting the aftermarket head for the tr...maybe i'll get a used one....thanks
rcabj is offline
Old 01-10-2005 | 02:11 AM
  #453
http://www.rcaddict.com.au/product_i...roducts_id/126 this is what the kawahara heads look like for the OS TR nice novarossi purple color!
Old 01-10-2005 | 09:04 AM
  #454
rc_king1's Avatar
rc_king1
what problems would you look for?
Well, lets see. I have probably 2.5 - 3 gal. through the engine. Its been ran in many races and practice sessions. I have yet to see the problems that you mention. Tell me what the differences are between O.S. turbo plugs and Novarossi turbo plugs please. From what I know (maybe not much) is that they seem to have the same thread size and pitch and seem to measure the same in length. I will continue to run these plugs because they work for me.
Thank you for your concerns
Regards
rc_king1 is offline
Old 01-11-2005 | 03:20 PM
  #455
Racing4Evo's Avatar
I strictly use Novarossi plugs in my motor. I've never had a problem. I think people are just using the wrong heat range. I almost always use a 7F which is the 3rd coldest Novarossi plug.
Racing4Evo is offline
Old 01-11-2005 | 05:12 PM
  #456
rcabj's Avatar
hi guys....i am in a bit of a problem
when i was using the novarossi engine i did add a thin shim between the engine and cone for the flywheel...everything was fine.
but for this tr when i do the same setup the amount of play for the thrust bearing is very, very minimal.
so my questions is whether adding the shim between the cone and the engine is a must? just to be sure, thanks
rcabj is offline
Old 01-11-2005 | 06:45 PM
  #457
oh ok well people at my track say no! as nova's have a different taper on the turbo plugs. but hey if racing4evo doesnt have a prob then you should be fine with them rcabj
now with the shimming aspect i believe its not a must. it only needs to be used when you can not see any space between the fly wheel and the front crankcase. Shimming is only needed to bring the flywheel out abit so it wont rub against the front bearing of the engine.
it think thats its purpose.
Old 01-11-2005 | 07:07 PM
  #458
rcabj's Avatar
thanks brain ... i think i'll loose the shim on this tr so that i'll gain back the proper freeplay for the thrust bearing...
rcabj is offline
Old 01-16-2005 | 05:03 PM
  #459
nsxshogun's Avatar
Anyone have a baseline needle settings? I need something to follow to make sure mine is somewhere in the ball park.
nsxshogun is offline
Old 01-16-2005 | 06:12 PM
  #460
Sofast-NT's Avatar
I bought a nocer heads for the trs on my ad2 & xxx-nt,they lowered the temps 40 degrees(240-245)to(180-200).Only thing is you need a millingmachine to take 20 thousanths off of the head so it wont touch the crankcase.
Sofast-NT is offline
Old 01-17-2005 | 01:32 AM
  #461
rcabj's Avatar
high speed ...1 3/4 to 1 1/2 turn from close
low speed...sorry i forgot)
mixture valve : from flush 1 turn in..
hope this helps
rcabj is offline
Old 01-17-2005 | 08:13 AM
  #462
nsxshogun's Avatar
Yep to cold out to try today though. I really need a low end needle setting. Anyone?
Old 01-17-2005 | 10:04 PM
  #463
on my tr-r spec i am getting a little over/under 10min, talk about great fuel consuption, the place where this engine likes the temp for me is about 200-215 degrees, great engine
rene is offline
Old 01-18-2005 | 03:19 AM
  #464
hey i've just checked my settings
high speed 1 and 3/4 turns out from closed
low speed 3 and 1/4 turns out from closed
Old 01-19-2005 | 02:42 PM
  #465
uaerc's Avatar
Hi there...
This is something i have been looking for quite sometime.. Just a quck qs.. Does this head just sit on a OS TR - T aswell without any accessories ? or extra parts or do i need to buy the turbo button seperate. ?
cheer
ZiiZo
uaerc is offline
