OS TR engine thread
Old 11-21-2004 | 07:30 AM
  #421
Default OS TR .12 R spec
If any of you guys are having problems getting this eng, PM me I have two new ones which I dont plan on using.
vadn1 is offline
Old 11-21-2004 | 11:34 AM
  #422
Racing4Evo's Avatar
Originally posted by BrainTeased
Hi may i ask what mods did you get done to your motor? just wondering if i should get both my crank and sleeve modded or just the sleeve.
I had both the sleeve and crank worked on. I'll see if I can get pics loaded up.
Racing4Evo is offline
Old 11-22-2004 | 04:57 PM
  #423
Marcos.J's Avatar
Super Moderator
Default Re: OS TR .12 R spec
how much?and do you have paypal?
Marcos.J is offline
Old 11-27-2004 | 07:04 AM
  #424
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
has anyone heard that sirio made a piston and sleeve for the ostr engine. is this true?? if so, how much will this kind of piston and sleeve cost.
doki_doki is offline
Old 11-27-2004 | 02:26 PM
  #425
tallyrc's Avatar
very early on sirio made an aac 5 port sleeve for it, but i am 99% sure it was discontinued...
tallyrc is offline
Old 11-27-2004 | 04:51 PM
  #426
smracer31's Avatar
ok, ive had my tr turbo for about a gallon of fuel and have been very dissapointed in its performance. I went to the track today and discovered the main front bearing has a leak, and a bad one, if i pressurize the engine fuel just pours out the bearing. Im not sure how long its been leaking as i didnt think to check it untill i realized today i had fuel under the engine. as far as performace i knew something was wrong today because it had a constant idle problem and was getting real hot when rich. so the leak explains it. before the leak problem tho the engine seemed to have very little bottom end power, but ok top end power, and no matter how much tuning was done to it it always seemed to run very rich and didnt really perform well runing at 220 degrees. When leaned out too 240ish it seemed to be fine on the top end but not on the bottom and was still rich. So i need to call os and send the engine in to be fixed, but i heard somebody saying they werent doing warranty for this engine because it was discontinued, is this true?
smracer31 is offline
Old 12-01-2004 | 02:46 AM
  #427
doki_doki's Avatar
i think os does not cover warraty for the ostr turbo engine mainly because it's a high performance engine. what i do know is that they carry warranty for the bashing type of engines like the os cv series. by the way, it's the first time i have heard about a poorly performing os engine. all the os engines i have bought are in very good condition. in fact, i have an os hyper cv engine is use for bashing around and still in very good condition considering its 3 years old. no parts have been changed yet...
Old 12-01-2004 | 07:32 PM
  #428
smracer31's Avatar
ive owned os's in the past, thats wy i a surprised i am having such difficulty. I mean no os engine ive had has been very competitive but i just wanted something that would be decent and reliable, and i guess the tr isnt that motor. btw im going to try and send my engine in, ill post here what they have to say.
Old 12-03-2004 | 09:07 PM
  #429
doki_doki's Avatar
ok bro...let me know what os has to say about your engine...
Old 12-04-2004 | 05:00 AM
  #430
BrainTeased's Avatar
guys i've countered my heat problem with lowering the body as much as i could! too the point it scraps the ground when running with very low foam tyres. it was a unexpecting find as i did this as an experiment as i witnessed all the other pro drivers at my club having their bodies very extremely low. now the window hole covers most of the bottom part of my engine as well now. and now im running 230-240F at the speed i use to run at 270...
BrainTeased is offline
Old 12-06-2004 | 01:35 PM
  #431
doki_doki's Avatar
thanks for the tip bro...
Old 12-29-2004 | 01:00 AM
  #432
rcabj's Avatar
guys...can a novarossi heat sink be fitted on to an OS tr....
rcabj is offline
Old 12-29-2004 | 02:35 AM
  #433
nah it cant i was hopping the same as well when i first got my OS TR with that small blue head
if you can try and get a 11 fin carlson head off rcmart
Old 12-30-2004 | 07:35 PM
  #434
rcabj's Avatar
actually i just got the os tr...haven't broken it yet... is it ok to use novarossi turbo inline pipe with the os...? thanks
rcabj is offline
Old 12-31-2004 | 08:02 PM
  #435
rcabj's Avatar
...i've just starting to break in my motor...
but it seems whenever i take off the glow heater it stall....
i've ask somebody and he told me that with o.s. the 1st 1 or 2 tanks with the glow heater on till the tank empty...is this quite true... after that only possible to break in without the glow heater on???
rcabj is offline
