Old 04-30-2005, 07:14 AM   #571
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: oil percentage ?? type of oils ?
Originally posted by mrgsr
hello
i just wanted to know what percentage oils you guys are running in your tr (mine is a r spec tr) ??
i am currently using 15% nitro with 18% castor oil
i notice alot of brown carbon like build up inside my egine on top of the ppiston and out side the car
thanks
john
what brand fuel?
Old 04-30-2005, 08:40 AM   #572
Trader Rating: 13 (93%+)
its just a brand of fuel that the hobby stores in australia sell
no major brand like trinity or so
mrgsr is offline   Reply With Quote
Old 05-03-2005, 12:14 AM   #573
Darth Vader's Avatar
Make sure it's not air-plane fuel.
Darth Vader is offline   Reply With Quote
Old 05-03-2005, 07:12 AM   #574
hey guys
i did some maths
and the fuel has 200mls to the litre of oil
in a litre that means it has 20% oil!! crap
im gonna make something useful from it and pour it over the weads in the driveway.
Old 05-03-2005, 07:37 PM   #575
yodace's Avatar
R/C Tech Charter Subscriber
Are they still making the TR engine..?
yodace is offline   Reply With Quote
Old 05-07-2005, 09:38 AM   #576
gfd2726's Avatar
Send a message via AIM to gfd2726
Default factory setting
Hi guys,
Recently, I got a used O.S .12TR 5ports (blue head) engine. It didn't come with any instruction so can anyone pm me the factory setting of this engine? Thank you.
gordon
gfd2726 is offline   Reply With Quote
Old 05-07-2005, 09:55 AM   #577
themoose's Avatar
I know it's been discontinued at Tower & they are a major OS distributer
themoose is offline   Reply With Quote
Old 05-07-2005, 09:20 PM   #578
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
OS has them on hteir website
Tire Chunker is offline   Reply With Quote
Old 05-09-2005, 03:19 AM   #579
rcabj's Avatar
Default Re: factory setting
Originally posted by gfd2726
Hi guys,
gordon
my base setting for it is....
-hsn...1 1/2 turn open from close
lsn- 1 1/2 - 2 turn close from flush.
and mid needle setting - 1 turn from flush... hope thats help..
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-09-2005, 10:45 AM   #580
gfd2726's Avatar
Thank you guys!
Old 05-15-2005, 06:06 AM   #581
Default os tr r spec fuel efficiency!
hey guys
just wanted to comment on the os tr r specs fuel efficiency
i cant believe after running a 5 min heat that i still have half a tank of fuel in my car
the engine still comes back pretty cool at about 80degrees celsius thats truly amazing. my mates collari 12 is lucky to finish the 5 min heat with a drop of fuel left.
However i did notice some fuel/dirt stuck under the low end needle so ive taken apart the carb and sealed it up with carb sealant to try stop that leak.
Old 05-15-2005, 07:02 AM   #582
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Hehehe- I like your username!!
BigDogRacing is offline   Reply With Quote
Old 05-17-2005, 12:58 AM   #583
Default Bearing freeplay
I have a question on the front bearing.
The one on my engine has about 0.5mm of axial freeplay on it. I noticed it when I stripped the engine to clean it. Only done 1 gallon through it. Now I'm a bit puzzled. Why does the bearing get damaged so quickly. As far as I know, there should be negligible axial load on the bearings.
Is it still ok to run the engine with that freeplay? Or will it tear up the con rod and crankshaft?
Any advice is much appreciated.
Cheers...
Old 05-17-2005, 03:35 AM   #584
rcabj's Avatar
Default Re: Bearing freeplay
Cheers...
i myself just gone through almost a gallon..and already the conrod need to be replace.....as for the bearing i don't see anything...
but if u have doubts u better change the bearing...
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 05-18-2005, 03:22 AM   #585
Default Re: Re: Bearing freeplay
Con rod koyak after 1 gallon???
How come...?
I think changing conrod is easier than changing bearing. It's a pain to remove and fit. Have to figue out how to heat up the crank case without damaging the other inner bearing...
RB Engine Thread snowboardgeek1 Onroad Nitro Engine Zone 515 06-16-2017 11:28 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 09:46 AM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 11:48 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 10:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 01:48 AM
