OS TR engine thread
Old 10-26-2004 | 02:43 AM
  #406
BrainTeased's Avatar
Originally posted by rcosmax
glad to here you like your os! Mine has been a rock solid performer for me. At the end of sundays race my os tr started to get tired out temps were still fine but it is just tired and compression has dropped and blowby can be heard. In no way is this a complaint as i have run this engine hard for around 20 liters. I am rebuilding it this week. Initial tear down showed that the bearings are in good shape and only p/s needs to be redone. I am very happy with how this motor has performed against the italian mills and for the price is definately a great choice.
ffr how much did your tq mod cost?
thanks.
did you have to change your con-rod within the 20 ltrs?
and may i ask what temps are you running?
BrainTeased is offline
Old 10-26-2004 | 05:07 PM
  #407
Yeah i changed the conrod 2 times (8 bucks for a conrod and they are almost disposable). My temps where ranging from 110-125 depending on track and conditions. It started to warp speed at the higher temps and never sounded lean but it makes me a bit nervous to get to close to the lean overheat. I always have this battle in my head of: man the engine sounds good and is very fast but maybe it is too lean and i back it off a bit. The plugs always looked good though. I guess i should just get rid of my temp gun and trust plug reading and sound tuning.
rcosmax is offline
Old 10-26-2004 | 07:09 PM
  #408
rcabj's Avatar
Default os/pipe combi
what is the usual pipe combi u guys use with the os tr....thanks
rcabj is offline
Old 10-26-2004 | 08:54 PM
  #409
I had used the kyosho 2 piece pipe that came with my fw-05. I dont have that car anymore so i can messure the stinger. but i think it was 5.2? After i had it ported and tuned i was using a zac flanged pipe that was 7.0mm. The best performance was the kyosho, but they are so fragile!
rcosmax is offline
Old 10-27-2004 | 01:10 AM
  #410
Sp Racer's Avatar
I'm using the OS T1032 with the kyosho header on my FW05 R...
beautiful!
Sp Racer is offline
Old 10-28-2004 | 08:22 PM
  #411
Where can i find a crankshaft collet to fit my new OS 12TR R-Spec engine.......?
FirstLoser is offline
Old 10-29-2004 | 07:16 AM
  #412
Where are you guys buying your E- Spec engines? Are there any online shops that sell them?
3434 is offline
Old 11-01-2004 | 06:31 AM
  #413
doki_doki's Avatar
From: Cebu City, Philippines and Ocala, Florida, USA
You can use the collet that comes with your kit
doki_doki is offline
Old 11-10-2004 | 08:54 AM
  #414
Default 12TR R-Spec engine discontinued
Does anyone know the story on this engine being discontinued by O.S.?
My friend put one in his NTC3 this summer and it's a stellar performer. I was planning on buying one.
i300i is offline
Old 11-10-2004 | 10:45 AM
  #415
Marcos.J's Avatar
Super Moderator
Default Re: 12TR R-Spec engine discontinued
as of today it is showing discontinued in tower hobbies
http://www2.towerhobbies.com/cgi-bin...&I=LXGPF1&P=ML
Marcos.J is offline
Old 11-10-2004 | 07:13 PM
  #416
Marcos.J's Avatar
Super Moderator
Default Re: Re: 12TR R-Spec engine discontinued
is now back in stock!
Marcos.J is offline
Old 11-11-2004 | 06:18 AM
  #417
and now discontinued again...
I placed my order for one yesterday.
Have there been problems with this engine, or is it just not selling well?
i300i is offline
Old 11-13-2004 | 09:28 PM
  #418
tallyrc's Avatar
can't wait to hear this answer.... maybe they decided to actually make a NEW engine rather than gussy up the tr and try to pass it off as new.......
tallyrc is offline
Old 11-20-2004 | 09:46 PM
  #419
Racing4Evo's Avatar
...or maybe they just want to repackage the motor and raise the price!
It's a shame really because the motor is decent. I'd equate it to a MT-12 but more bottom end! So long as I run the motor above 240deg. it has good power. I ran it a whole day at 250 deg. 80 minutes of racing. C, B and A main. The temp was consistent and no sign of detonation. It isn't quite a Novarossi killer on those bigger tracks, but it sure is an awesome small track motor. Granted my motor has been worked on, I wouldn't hesitate to run it stock so long as the track isn't too big. I lost some gas milage with the modification but it's still awesome compared to the Novarossis. I got 7minutes with it stock and now I get 5:50 with the mods.
I also noticed something very weird. The compression got better after 2 gallons. I've never had this happen to me before. I am absolutely sure the compression increased since the last time I ran it. I'm not exactly sure why but it's very interesting. Anyone have insight as to why?
I also reccomend the new VR 12 pipe from Skyline Racing. I just got the pipe and it really exploits all the power from this motor. I was running a RD pipe, a Yokomo pipe and a Rex pipe on this motor and so far the Skyline pipe has been the best.
Racing4Evo is offline
Old 11-21-2004 | 01:16 AM
  #420
Hi may i ask what mods did you get done to your motor? just wondering if i should get both my crank and sleeve modded or just the sleeve.
