Old 07-03-2009, 11:55 PM   #1021
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Smile
Originally Posted by kmh View Post
Do you mean closed as in shutdown,out of buisness? Does this mean that there will be no more JP engines or parts or will we just have to use novarossi parts in the JPs'?
out of buisness. I have. A jp 35 & ro 3 also couple fx12s don't know what to do now he sent me a replacement crank for the 1 above was good good luck jp followers
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 07-04-2009, 12:31 AM   #1022
stefan's Avatar
Send a message via AIM to stefan
I talked to someone who knows Jean Paul personally and he told me that JP wants to retire and was looking for somebody to take over his business, but obviously couldn't find anyone. Therefore he's shutting the place down.
stefan is offline   Reply With Quote
Old 07-08-2009, 06:10 AM   #1023
Default Jp fx-03 piston
Can anyone verify that this is a Cnc machine piston? I know it's the same sleeve set as the 321 engine and it comes with microcast piston. I started break in process and it acts like a microcast piston although jp website says it's cnc machined.
no4hitter is offline   Reply With Quote
Old 07-10-2009, 07:33 PM   #1024
Trader Rating: 27 (100%+)
Hey guys, I have in front of me what should be two JP FX21 B5N motors
One case says JP FX21, the other case says NOVA S21 Novarossi, both have JP Engines B5 blue head
Can anyone possibly tell me if there is a difference between them?
The one that says JP on the block has a serial number engraved into the side.. not sure if that's JP's s/n or something another modder put
Thank you!!
spawn_x is offline   Reply With Quote
Old 07-10-2009, 07:47 PM   #1025
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Thank you!!
The B5N is JPs version of a P5. There is a black version and a stock version, but basically, they use P5X cases. The S21 is just the OEM Novarossi case, so it may have been swapped or used at one time. Are the cases black or silver?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-10-2009, 08:06 PM   #1026
Ahhh okay. The cases are both silver, not the black version but I got them both at a good price!
Thanks for answering my question!
Old 07-11-2009, 07:51 AM   #1027
ezveedub's Avatar
Depending on the versions you have, it could have the P5 sleeve or the P5X sleeve. Both should have black coated, lightened cranks with red filler.
Old 07-12-2009, 10:11 AM   #1028
So what does JP do to them, aside from the crank? Mod the ports too?
Old 07-12-2009, 10:17 AM   #1029
ezveedub's Avatar
On the Black versions, the crank and sleeves are ported. On the stock, they usually just use a stock sleeve with black coated, lightened cranks, but if you really look into them, sometimes the piston used is certain part that the Nova's don't use, or a case and backplate that also different from the Nova version also.
Old 07-14-2009, 09:41 PM   #1030
thank you, I appreciate that. so they mix and match?
i took apart my new (used) b5n and everything says Nova - rod, button, block, etc. my other b5n, nothing on it says Nova, only the carb..
both have black cranks with red putty
that sounds like its possible?
Old 07-14-2009, 11:00 PM   #1031
ezveedub's Avatar
Yes, they are Novas with JP black cranks. The Black versions have tuned cranks and sleeves. Since they are P5 based motors, they could be an assortment of different series of parts in them, from R4 to R7 rods and different sleeve designs, but still 5 ports.
Old 07-14-2009, 11:22 PM   #1032
lil-bump's Avatar
Trader Rating: 83 (100%+)
I'm confused. I checked the real head clearance of My JP fx12 To3 (stock). With no shim in it; the real head clearance is .50mm this is more in line with 16%. I thought with 16 % you would add the optional .30mm shim
any comments>>>
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-14-2009, 01:18 AM   #1033
Hey guys, I got a JP FX-T05 and the red putty has blown up into pieces, got stuck in my transfer ports. Seems that this putty is red RTV? like the Permatex hi-temp Red? I tried refilling the void that JP makes plus the ramp, but I just cant get it smooth. Motor still runs fine, but it just looks ugly. If i thin it down, with Naphtha, or mineral spirits, or w/e, it shrinks a bit. I found this old thread on this putty:
http://www.rctech.net/forum/exclusiv...nk-shafts.html
but whats the secret to making it smooth?
Quark is offline   Reply With Quote
Old 08-14-2009, 03:32 AM   #1034
ezveedub's Avatar
You can get the red filler from Reid RC.
http://www.reidrc.com/news.htm
"The crank filler rtv is now available and in stock. A self leveling one component red rtv.
$24,95 per 3oz tube, e-mail [email protected] for order or more info. Tuners and Modders welcome."
Old 08-15-2009, 10:45 AM   #1035
lil-bump's Avatar
Who still carries JP engine parts. Looking for a Turbo button head for a
JP fx .12 to3 stock.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
