Like Tree1Likes
JP engines
Old 07-24-2008 | 05:53 PM
  #811
Team Kamikaze's Avatar
Originally Posted by Arahawak
If you say 2630 is completely shit, then I am in trouble. Apparently, I am unable to lay my hands on a 2602 or a 2601 pipe!!
Everybody's out of stock or it is out of production or everybody grab it for the Worlds'???
I got MAX 2602 pipe sets in stock, anyway the Nova Rossi 2630 is not a bad pipe, the only draw back is it's a gas hog, but will definitely give a lot of power to your motor, you just have to re-tune your engine correctly when switching from 1 pipe to another, If it is your first time using a 2630 pipe, you will definitely need to richen your HSN, if not you will be running lean and will end up overheating your engine.
Team Kamikaze is offline
Old 07-24-2008 | 06:32 PM
  #812
Arahawak's Avatar
Originally Posted by DS Motorsport
@ arawark, yes i know, really hard to come by, maybe try if you can order the pipe at a european site, but even i cant get any mega 2602 pipes any more and i live 10 minutes from the serpent factory.
European sites cost a bomb. I'm not sure why but it does cost me an arm to get it.
Arahawak is offline
Old 07-24-2008 | 06:35 PM
  #813
Arahawak's Avatar
Yes we are considering if we should get the 2602, we will contact if we decided to.
So far, I am getting mixed results from the 2630, that is why i am holding back on the purchase. I only know so far the Nova 2601 and Max 2602 has given me the confidence.
Arahawak is offline
Old 08-19-2008 | 07:25 AM
  #814
Bad Mika's Avatar
Default urgent help needed...
Hello all JP lovers ,
Need some urgent help and advice...
I just got my first JP, was very excited about it but unfortunately the clutch bell bearings ARE NOT ABLE TO SLIDE IN to my surprise
I have other engines nova 353, os tz, nova max etc... and never had this problem but this is my first JP , by the way my clutch set is from the mugen mtx4r...
Appreciate if anyone could share if they encounter any sort of this experience... Many thanks !
Bad Mika is offline
Old 08-19-2008 | 07:30 AM
  #815
chicky03's Avatar
I've had that same experience with some other nova based engines. Some bearings fit on and some don't. I just took some fine sand paper and sanded the crank until the bearing fit on. It's something I have heard others having to do the same thing.
Paul
chicky03 is offline
Old 08-19-2008 | 07:38 AM
  #816
Bad Mika's Avatar
Paul
Thanks Paul for the super quick reply
By the way, any type of sandpaper is ok or need special one since we're sanding the crankshaft ??
Many thanks
Bad Mika is offline
Old 08-19-2008 | 07:43 AM
  #817
wingracer's Avatar
An emory cloth would probably be best but most any fine sand paper should work I would think.
Fotunately I haven't run into this problem yet.
wingracer is offline
Old 08-19-2008 | 08:23 AM
  #818
fpart's Avatar
Can someone tell me where I can get JP Engines in USA?
fpart is offline
Old 08-19-2008 | 09:17 AM
  #819
JetMD's Avatar
I think these guys are in the u.s. I've never bought from them though so i'm not sure.
http://www.rcnitronation.com/
JetMD is offline
Old 08-19-2008 | 09:53 AM
  #820
Seisick's Avatar
have any hobbyshop that is dealer from mugen order that engine
they have the eagle 12 tuned and also the first line black as well as the eagle 21 on road.
Seisick is offline
Old 08-19-2008 | 10:25 AM
  #821
Have you local shop call Mugen USA. We have all JP engines and products in stock!
Mike_Swauger is offline
Old 08-20-2008 | 08:40 AM
  #822
Bad Mika's Avatar
Default help...
Hi Mike, all
Just wondering if you ever heard or face with a problem of clutch bearings unable to slide or go into the crankshaft of a JP engine... I'm facing this problem at the moment, and not only me but my buddy's engine also, we just bought both engines together.
I am using the mtx4 clutch bell/set with a JP FX12-T03M black case edition.
Would probably be sanding it down but would like to get some opnions first..
Thanks in advance...
Bad Mika is offline
Old 08-20-2008 | 08:51 AM
  #823
wingracer's Avatar
Hi Mike, all
Read up just a few posts.
Old 08-20-2008 | 09:02 AM
  #824
Hi Mike, all
Yeah, sometimes this happens. Use emory cloth like wing racer said and you should fine.
Old 08-21-2008 | 07:38 PM
  #825
Arahawak's Avatar
Hi Mike,
Could not get my hands on the emery cloth but i got a 1500 grit paper and gave it 2-5 rounds on the crank and the bearing slide in like silk.
Just a thought, being JP, isnt there a QC on the cranks? This is the first engine and first JP i had encountered. I went through 4 JPs before this.
Arahawak is offline
