JP engines
#767
wrong the rear bearing is 25.8x14x6
same as a P5,528,R01,JPB8,JPB5
Mrx4-R03, is right you can not use any plus engine bearing in a jp apart from a jp modified Novarossi 35plus21 the jp-ro3 uses a 25.4mm outside dia 14mm inside dia and 6mm wide rear main bearing and the plus 21 rear bearing size is 26mm outside dia 14.5mm inside dia and 6mm wide. I wish people would do some looking befor they make recamedations. 1.6mm outside dis is a masive difrence and 0.5mm inside difrence is also huge. Regards Jeremy.
#769
Front = 7 x 19 x 4mm
Rear = 11.5 x 21 x 5mm (Ceramic on a Full option engine)
www.kamikazetoysandhobbies.com
#771
The Eagle R9.S is available just ordered one from http://www.storm-discount.com they are cheap to
any one tried one yet how dose it preform?
#774
#775
The FX 12 Eagle for even more performances. Already known like L’one of the most brilliant engines of the market, the FX 12 T03 comes to undergo some modifications in order to give in Eagle version even more power to this 3 transfers to standard EFRA. These modifications follow upon a long year of competitions, tests and developments with the best pilots of the moment. This various lesson led JP Calandreau to optimize even more this animal of race which quickly will become a reference. The Eagle model was modified and optimized with a race slightly longer to give to the pilots most demanding more power with low mode without losing the incredible speed which makes the reputation of engines FX. The tests have validated these modifications for several months and you will be sure with this one to benefit fully from the performances and the experiment given to best pilot.
Card-index Technique FX 12 TL-3T Cubic capacity:2,09 DCBoring:13,70 mmRace:14,25 mmNb Transfers:3Crankshaft:ø 11,5 mmCarburettor:ø 5,4 mm + tubeCandle:TurboWeight:223 gr.Reference: FX 12 TL-3T
Reinforced Black CasingThe casing of the Eagle model is reinforced with the fasteners of the stages engine and the top of this one is redrawn to receive the shirt whose higher flange is broader. Like all the models FX, the casing is treated black for an optimal dissipation of the calories and also in order to harden the ranges of the bearings and to improve their behaviour in time. This treatment avoids the internal oxidation of the casing by the fuel which can remain after use and the problems which result from this.
This casing is, like all the casings of engines prepared JP Racing, the claw of the mark and its identity since nearly 20 years.
The stopper of casing is specific to this engine with the longer race. A notch was practised to place the skirt of the piston in position low point-death.
Cylinder headThe cylinder head of Eagle 12 is broader in diameter than the old cylinder head of models FX 12 but it is lower in order to notably lower the centre of gravity of the engine is to descend the roll center from the frame. With its 6 wings it ensures a perfect cooling of the high engine. Of blue color it is engraved with the colors and reference of the engine.
TURBO InsertL’Turbo insert is specific to the Eagle engine and made the object of long tests and research at end to optimize the compression and the good behaviour of the candles in competition. The insert penetrates more deeply in the shirt for a greater sealing. The decompression of the engine is particularly optimized and measured individually to ensure of the equal performances for all the engines. Its broad insert allows an optimal exchange with the cylinder head and cools in an optimal way the top of the cylinder. Like any engine of competition, this insert is of Turbo type.
CAUTION: It is very important to use Novarossi candles for this engine because they only ensure an assembly and a perfect sealing with the insert. Certain badly adapted candles can return the engine inréglable and deteriorate the insert and the engine.
Line piston 3 ABC TransfersConform to 100% with the specifications of standard EFRA and IFMAR with its 3 transfers, the shirt piston of Eagle was completely reconsidered. Smaller boring, broader flange, exhaust and different transfers in form and timing, Eagle is resolutely different for even more performance. The piston is, like the evolution of model FX T-03, convex for a better admission and a more effective sweeping of the cylinder and combustion chamber. The rod is equipped with 2 rings bronzes for a great longevity and its materials of the aviation type was checked of the aeronautical type for an optimal reliability counts held of the performances of this new engine.
Crankshaft EFRA/IFMAR The drawing of the crankshaft of Eagle 12T gives to this engine very strong rises in mode thanks to a gas conduit generous and adapted to the performance of this engine. Its balancing is studied for the moving element rod piston of Eagle and gives a very great longevity to the bearings of the engine. Its conduit and the drawing of its plate is carried out for a perfect flow of gas flow. The shape of the conduit of the crankshaft allows a greater admission of gases and an addition of couple all the modes. For even more performance, the timing was still improved and that without concession for the consumption which remains lower for such a powerful engine.
Like all engines JP Racing and that since more 20ans, the red paste is placed in the conduit to improve gas flow and to reduce the moment of inertia of the crankshaft. The Eagle crankshaft is treated HardBlack for a longevity without similar and a coefficient of friction of low.
CarburettorThe carburettor is out of aluminium with interchangeable tubes of 5,4mm. As on all engines FX 12, the adjustment of the recovery is done on only one screw for an adjustment even simpler and more fiable.Ce carburizing already proved reliable and confére with the moter Eagle 12 a very great stability of adjustment and a great performance.
#778
does palmaris still makes piston/sleeve kit for jp fx12-t3??? or how much usually does it cost from jp??? btw, i think my engine currently is using the palmaris brb piston/sleeve n they have this number 11 marked on sleeve n piston... does it means anything???
#780
the number 11 should match the piston number 11(when new, u can see on the very top of the piston). THis just number off the production line and matching the piston and sleeve.
1Likes
