Like Tree1Likes
JP engines
Old 09-11-2006 | 06:05 PM
  #646
wallyedmonds's Avatar
LOL
wallyedmonds is offline
Old 09-23-2006 | 05:43 PM
  #647
Originally Posted by Racing4Evo
The two engines are identical except for the sleeve material. The R-01 is an aluminum sleeve (AAC) just like the old 421P from Novarossi. For some reason or another(longevity maybe) they discontinued the R-01. The R-02 is the 7 port version. Get an R-03 if you have a choice.
*I just checked the website and it says differently. BUT, going on my past experience and watching the JP motors that others around me have used I stand by my statement.
I just got an R03 with a total of 8 tanks through it. Do you think I should swap the conrod now? Will the R7 work best with the R-03?
Thanks for any advice.
going4#1 is offline
Old 09-23-2006 | 10:32 PM
  #648
daniz24's Avatar
Regional Moderator
Originally Posted by Team Kamikaze
Correction there is no JPFXT03T it is JPFXT03MT
The MT is microcasted piston and the T is CNC machined piston. The MT is faster but the T is more reliable for me
daniz24 is offline
Old 09-25-2006 | 04:15 AM
  #649
Suspended
Default R7?
Those 8 tanks are with breaking in? If yes then replace the conrod if not than can go upto 2,5l 20 tanks.
You can better place the R5 or the new R6.
PMSorber is offline
Old 09-26-2006 | 10:10 PM
  #650
I've been told the R7 is NOT compatible with the R01/R03 engines. The reason being given that the conrod is thinner than the crankpin of these engines allowing the conrod to move back and forward. I've got an R7 myself though and it look identical in width, height and length to all other standard Novarossi conrods. The groove cut down the centre is different though. I'll try and report back.
I've also been informed that JP is now not offering R6. True? I wonder. I've seen web sites still selling it but I have a friend who is in the RC business and he says R6 users (R6 being the conrod without the bushing running with the black coated wrist pin) have met with disaster using the R6. Until now I've only used the R5 and the R4 (which I use for break-in). Maybe I'll stick with the R5. Right now the biggest weakness is my driving. No conrod out there is going to fix that.
going4#1 is offline
Old 09-27-2006 | 04:40 AM
  #651
Suspended
No they still offer the new R6 conrod
JP R6
We used the R6 now for 2 National races (2 liter) and I have to say, they perform better than the R5. No problems found upto now!
PMSorber is offline
Old 09-27-2006 | 05:53 AM
  #652
JP R6
That's good to hear. I may try one myself. What percent nitro are you using? 25? How many shims are you using on the underhead?
going4#1 is offline
Old 09-27-2006 | 06:08 AM
  #653
Suspended
25% JP-Fuel. The ammount of shims differ per type of engine but in general we place .55 to .65mm.
PMSorber is offline
Old 09-28-2006 | 12:24 AM
  #654
I'm using the R03 and R01. So .55 - 0.6 okay?
I'm getting an order of JP fuel next week. I've gone through a couple of gallons of Cosmo but don't like it much. Good punch but setting the engine is just too hard. When you're lucky the engine is fantastic but most of the time the engine either under-performs or overheats.
going4#1 is offline
Old 09-28-2006 | 01:37 AM
  #655
Suspended
Sounds ok but be aware that this is depending upon fuel consumption, type of track, engine etc etc. I assume that your R03 does not have .55 on top?
PMSorber is offline
Old 09-28-2006 | 02:31 AM
  #656
team novarossi's Avatar
depends on amount of nitro youre running, track location (sea level or above)
the 35 plus engines i got are made in the italien alps, so they made with .5....in holland where racing at sea level so you need to add +.1mm
hope this helps
team novarossi is offline
Old 09-28-2006 | 07:36 PM
  #657
hope this helps
We're close to sea level (~100m) so it looks like I need to add .1mm. Engine comes with the standard spacer.
going4#1 is offline
Old 09-29-2006 | 09:49 AM
  #658
SalvadoriRacing's Avatar
I don't think the fact of a factory being placed at high altitudes is the reason they built their engines properly shimmed to that specific altitude.......
every engine come from the factory with a safe margin considering altitude and fuel nitro content and quality.........
SalvadoriRacing is offline
Old 09-29-2006 | 10:35 AM
  #659
does anyone know the hp rating of the jp fx t03s, thats the stock version, i just wanna know the difference between that and the novarossi ll3, if there close.
Gervais is offline
Old 09-29-2006 | 02:42 PM
  #660
DS Motorsport's Avatar
Stock version is very fast, at a high speed track the difference between the stock and modded version was only 2/100 of a second.
The stock version is also very smooth on the powerband.
It works best with the 2601 or 2602 pipe with a short conical header.
DS Motorsport is offline
