Old 12-13-2005, 10:15 PM   #526
rcabj's Avatar
Originally Posted by rcabj
hi..anyone can give me some info on this engine>>>on the purple head writen Jp racing and NS5 , with black crankcase..thanks
also can anyone give me base needle setting for it...thanks
(my other nova was 4 and half turn for top / 3 half for bottom ...)
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 12-14-2005, 02:23 PM   #527
Send a message via ICQ to markallen Send a message via Yahoo to markallen
Can anyone who owns a modified JP FX 12 T-03 measure the height of the exhaust port from the top of the sleeve?I want to see how my stock port measures up..
Thanks,
Mark
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 12-14-2005, 07:36 PM   #528
rcabj's Avatar
already got the motor running....previously the top endd was rich and the bottom end was lean....now its running well....just need fine tuning for race pace...
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 12-16-2005, 08:58 AM   #529
Trader Rating: 15 (100%+)
I have a JP X12, when I took the engine apart I noticed that the bore thru the crank is the same size all the way thru it except for the end right where the counter weight is. It looks to be something in the casting of the crankshaft. The hole that the fuel comes thru gets smaller by about 1mm. Does this sound normal? If not can I smooth it out with a dremel? Anyone have any thoughts on this one?
THE DOCTOR is offline   Reply With Quote
Old 12-16-2005, 01:06 PM   #530
GrandeGixxer's Avatar
It is probably to improve flow while still keeping the hole at a legal size. If it is something JP did, dont mess with it.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is online now   Reply With Quote
Old 12-16-2005, 07:21 PM   #531
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
it's called venturi system........
it's supposed to work as the venturi on carb intake, but I don't think it makes any difference, I also have tried a M. Rossi shaft in a JP and the engine worked even better and less crictical........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 12-16-2005, 08:27 PM   #532
I thought that a venturi was used to suck liquids from a tube in the center of the venturi. Does not sound right to me. Do you mean a volacity (spell?) stack.
Old 12-17-2005, 07:41 AM   #533
the venturi accelerates the fluid..........
flow keeps the same, then the reduction of the area demands higher fluid speed..........
this is why it doesn't make any difference (in my opinion of course), the mixture quantity that gets in the crankcase is pretty much the same, it just gets in faster, which in my opinion means nothing since the matter is how MUCH mixture is entering and not how FAST it's done......
Salvadori Racing
Old 12-21-2005, 09:44 PM   #534
rcabj's Avatar
....... well that was not what happened during race...the engine would cut off in the mid of the 5 min. heats ( in all 3 heats)...
idling was fine , . ( and it was always easy to restart after stalling) my temp. is only 98' celcius....
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 12-22-2005, 06:55 AM   #535
Regional Moderator
daniz24's Avatar
Flaming out is often caused by too rich setting. You can close the top needle a little bit more if you're still running on 98C in your country.
daniz24 is offline   Reply With Quote
Old 12-22-2005, 07:10 AM   #536
Sounds like it needs to be leaned out. That temp is a little low but not by much. I usually will run around 240 deg F. which is I think around 115 deg C.
If the engine starts up quickly that is most likely what is happening because if you overheat the engine it will take a while to cool down enough to start up again.
Old 12-27-2005, 10:08 PM   #537
rcabj's Avatar
thanks guys....
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 12-28-2005, 01:49 PM   #538
R/C Tech Charter Subscriber
Is the JP2 a good pipe for a FX21B5N?
NismoSkyline17 is offline   Reply With Quote
Old 01-05-2006, 04:40 PM   #539
ogreasurada's Avatar
JP-O.S engines coming soon! www.mugenracing.com
ogreasurada is offline   Reply With Quote
Old 01-05-2006, 05:48 PM   #540
n.e.r.d's Avatar
NismoSkyline17,
i've used the JP2 with both my max M5T (nova P5 based like ur B5) and V-Spec, works well with both engine. good mileage(8+mins on my M5) and excellent durability.
the JP2 is a top-end pipe, suitable for engines with lotsa bottom power. not the most power overall tho. the nova/RB 86 will give your B5 the most top-end power (at the expense of mileage and durability).
and btw, if you're getting the JP2, get the polished version. i've tried both polished and hardcoated, the latter seems lesser powerwise.
n.e.r.d is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
