LRP nitro motors
Old 07-14-2007 | 11:53 PM
  #241
Dynamite's Avatar
spec2 should kill a d3r.
this motor comparible to sirio evo3, nova plus 12 etc.
Dynamite is offline
Old 07-15-2007 | 08:14 AM
  #242
charlesd's Avatar
I have an rdlogics turbo 2 pipe, is this pipe ok with the spec 2?
I read through the forum and not much is talked about the spec 2. Infact it's hard to find any info at all. I guess lrp ditched the engine for the spec 3 as it's not even on their website. In my mind associated makes good kits so this engine should be good.
Any problems with reliability?
charlesd is offline
Old 07-16-2007 | 04:50 AM
  #243
charlesd's Avatar
Well, i took the plunge and bought a spec 2 .12 for my g4s. I'm hoping my rdlogics pipe works well with the engine. If there's any feedback on this combo, let me know as it will be 2 weeks before i get the engine.
charlesd is offline
Old 07-16-2007 | 02:50 PM
  #244
impalabob64's Avatar
Thumbs up hey
i recomend the mega pipe combo,or the sirio 2611 pipe an header combo.trust me i hve ran this engine be for.
impalabob64 is offline
Old 07-16-2007 | 02:54 PM
  #245
Default also
the motor likes to rev like the mega zx12
Old 07-16-2007 | 08:18 PM
  #246
charlesd's Avatar
Any good online shops that carry either one of those pipes?
charlesd is offline
Old 07-17-2007 | 08:43 AM
  #247
Default HobbyStores
PNP Hobbies,or Supierorhobbies
Old 07-29-2007 | 06:59 PM
  #248
Default Team Spec 4
http://rcforum.co.kr/news/entry/LRP-Z12R-Team-Spec4
Does anyone have the engine or know if the new lowered cooling head can fit a Spec 3 ??
Does anyone know where I can find LRP .12 pipes ?
jelayne is offline
  #249
Default Team Spec 4
thanks
jelayne is offline
Old 07-30-2007 | 03:33 AM
  #250
charlesd's Avatar
Default problem with the low end on spec 2
Well i tried my spec 2 for the first time this weekend and I believe this will be a good club engine.
I did have a problem with the low end. The top speed of the motor was very good and the top end worked flawlessly on the back straight. The second i would take a corner and accelerate, the engine was sluggish on the technical part of the track.
My temp was 255f and it pretty muched stayed there. My low speed was 1.75 turns out. I didn't want to lean the high speed out more as the top end was good.
My question is: in your experience is the kind of engine that likes to run hot and is 1.75 on the bottom not enough?
charlesd is offline
Old 08-06-2007 | 01:26 AM
  #251
Default LRP z.12 sepc3
hi,.... can any1 plz advise....
what is the factory setting for LRP z.12 spec3??? how many turns for the high & low speed needles????
tq
hobbs is offline
Old 08-06-2007 | 09:26 AM
  #252
charlesd's Avatar
Lrp engine model: 31202
low: 6.75 turns
High: 5 turns
If you need the manual, go to: http://www.lrp-electronic.de/index.htm
go under products, nitro engines, then find your model and all the info is there + the user's manual.
Does anyone know if the spec 3 carb is the same as the spec 2? In my manual my low speed is at 2.5 turns.
charlesd is offline
Old 08-06-2007 | 04:30 PM
  #253
quietstorm76's Avatar
Have you checked your clutch? I've ran the Mega/Picco 12's and I had the same problem until I readjusted my clutch. Also check your first gear ratio.
quietstorm76 is offline
Old 08-06-2007 | 05:14 PM
  #254
charlesd's Avatar
Ufo 2 clutch on it's way. I'm using 19pinion/47 spur.
i'm also thinking it's my clutch. My next race is this saturday and hopefully i will have the new clutch in time. If not, i will use my old parts but i'll try different shoes.
I was reading a old race reports from 2004-2005. If the engine won races in those years, it must be me who is setting up the car wrong. I also have another pipe to try incase it's that. I have a good pipe but it may be incompatible.
charlesd is offline
Old 08-14-2007 | 07:08 AM
  #255
charlesd's Avatar
Default Not having much luck with the motor
I'm not having much luck with the motor.
I got my new clutch and asjusted that saturday morning. It grabs good and i know there's no slip in the clutch.
I got the car on the track and got the car to the point where the speed and acceleration where good but no idle. The second i let off the gas, the car died. Also the second i hit something - even very lightly, the engine cut off.
I richened the low speed and adjusted the idle and the engine seemed fine. Good speed all around and the temp was around 240-255f. By the way, because of our weather, 250f is quite normal here.
I get the car off the track to install tires,etc... Put the car back on the track for the qualifier and the engine is running really rich. No speed at all. The weather didn't really change. We re-adjusted the engine on the high speed needle just a hair. then it ran good.
The next qualifier, the same thing. i didn't touch the engine and the thing ran really rich. We retuned the hsn. The same thing happened in the 3rd qualifier.
during the race, my car cut off at about 8 minute mark. We pulled the car in and my plug was dead. Put another plug in and out i go. since the plug was a different kind, we had to retune a hair leaner. At about 15min the car died again but this time the engine was at 340f !!!!! I stopped the engine and let it cool down. I went back out at 20minutes with an rb 7 cold plug and finished the race. The car finished with a temp of 280f.
This is freaking me out. The engine just seems to re-tune itself. I'm presently sealing the carb, back plate, changing my gas tank and fuel lines.
Are these carbs known to loose a tune?
charlesd is offline
