Old 05-20-2007, 02:32 AM   #226
stefan's Avatar
Send a message via AIM to stefan
9 turns, damn!
Doesn't the needle fall out?
I have been running 6.75 turns, like LRP recommends, but I'll try your suggestion.
Originally Posted by Fabian K
Ok, Let me see if can help you sorry the bad english ;
I have race LRP .12 engines since the first one ,later sepc2 an spec3 now,
of course your head shims need to be correct by the % percentage ok
this engines likes and works perfectly with the botton en needle too rich, try to use aroud 9 turns opened dont worry its too much ok but works,
later this maybe you will never need to touch/tune again on the booton end
needle , to check if the botton end is fine , try this; run the car same way you run on the race, fastest you can around 3 laps , come to the pit, stop the car, and lift the front end of the chassis your car you will put the car almost on vertical the engine this time will want to rich a lot and want to die , here is the best point, if not you will need to rich a little bit more the low end needle, if the engine die before this the low end is too rich, this tip works because the car on vertical position makes the fuel inside of the tank goes easy to the carburator and make the engine rich alone,
Of course before you tune the botton end is better you tune the main needle , go to the track with main needle rich, your second speed maybe does not shift or shitf too late , start to lean 1/8 of turn each time until your engine show you a very good power so later this stop to lean or just go moore 1/8 maximum , later this go to tune the botton end like i told above,
The LRP engines does not work same procedure like nova based or anothers to have a good power on botton you need to work too rich on botton needle
Dont be afraid to rich a lot the botton end the more you rich better will be until the point of the engine die when stops
Try,
I hope will work for you
stefan is offline   Reply With Quote
Old 05-20-2007, 08:27 AM   #227
Default LRP settings
Guys can you tell me what is the default settings after breakin for the SPEC 3
thx
jelayne is offline   Reply With Quote
Old 05-20-2007, 07:38 PM   #228
lil-bump's Avatar
Trader Rating: 83 (100%+)
I just had my first race with the spec 3 this engine scoots.I could keep pace with JB's and novarossi down the back straight. I had a little trouble with the engine loading up with fuel during the technical section of the track I just leaned out the low end a little at a time. By the second qual it was like a rocket temps ran around 225-235. It was really cool at the track.I had to switch to a med plug.The temps hovered around the 60's all day took almost three laps to get the engine up to temp. all in all a great little mill
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-20-2007, 07:52 PM   #229
Team Kamikaze's Avatar
Originally Posted by Sp Racer
...so the saga continues
the top of the piston is very dark ( obviously hot) , yet the engine still runs cool
Damn strange...
Just want to clear something up if the Top of the piston is very dark, it means it is running on a perfect tune not running hot at all, it is actually running on the rich side, not as you indicated that it is running hot. a badly pitted or like sandpaper surface is the indication of the engine running hot.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-21-2007, 08:07 PM   #230
Send a message via MSN to Fabian K
Originally Posted by stefan
9 turns, damn!
Yes, dont worry about too rich botton end needle , yes the needle goes outside too far dont worry no problem, i know LRP says 6,75 turns ou, but never works to me , the engine after just a few laps had problems with power on botton end due this settings , so i solved and worked very good on botton end needle very very very rich , same on my SPEC , SPEC 2 ......., and tune/lean the main needle until you reach a very good top speed thats all i do .
Fabian K is offline   Reply With Quote
Old 05-21-2007, 08:34 PM   #231
Fabian K - check your PM
I have tried richening up the bottom as you suggested, the problem is when I run it so rich, after straight when the excess rich mix clears out, the engine wants to run on, if I lower the idle speed then it loads up and wants to cut out.
Even though I ran the engine like this, after 10 min - lean bog, the top of the piston is very dark ( obviously hot) , yet the engine still runs cool
Damn strange...
my engine also is very dark on top of the piston do not worry like guys said its a little rich sinal , and its not danger color
Sp racer;
I answer your pm add my msn; [email protected]
Old 05-24-2007, 08:34 PM   #232
lil-bump's Avatar
Do the OS turbo plugs fit the Lrp spec3 engine
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-30-2007, 07:06 AM   #233
OS plugs fit and work great
Guys how do you resent you reset your main needle and mid needle, do you all back them in all the way and start your turns from there ???
Old 05-30-2007, 07:18 AM   #234
Dynamite's Avatar
Send a message via MSN to Dynamite
the taper of the plugs are different... not recommended.
get one of each and look at the conical (bottom of the plug), if you look at it and measure it you will see what i mean.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 05-30-2007, 07:22 AM   #235
Dynamite's Avatar
about the carby q.
generally wind the needle all the way in until it stops, and count from # turns out.
so if the setting was say 5 turns on the high speed: wind high speed all the way in until it stops. then count 5 complete turns out from closed.
hope this helps
Old 06-10-2007, 03:39 PM   #236
lil-bump's Avatar
Who carries the Picco or mega 2607 pipe. Looking for an good combo for a lrp spec 3 engine
Old 06-10-2007, 07:59 PM   #237
Originally Posted by Dynamite View Post
about the carby q.
hope this helps
Sorry for the late reply, thanks Dynamite
Old 06-25-2007, 04:21 PM   #238
Sp Racer's Avatar
Finally starting to see some light at the end of the tunnel!
A big thank you to everyone that tried to help - I had the mighty Spec 3 absolutely flying last weekend at a local club meet.
It seems the problems I was having were maybe a combination of clutch setting, engine tune and pipe ! ( no wonder I struggled!)
Still, I am chasing that setup where the engine idles nice and doesn't load up excessively...at the moment , it will idle for 10 sec and load up to the point that it stalls ( but still idles long enough for a pit stop) maybe just a matter of sneaking up on the low end needle a bit at a time until it's just right
The current setup on my engine is...
LRP #7 plug ( sidewinder 16% race blend) 0.45 head shims, 1.5mm clutch nut pre-load (RRR)
Max power conical header with 2602 pipe...bottom end needle was approx 7 turns out (AZRI, this pipe combo , a lot more power and RPM than sirio 2611)
I found that gearing down first gear gave the motor some real punch out of the corners and It seems like it can pull a taller 2nd gear..
Sp Racer is offline   Reply With Quote
Old 06-26-2007, 07:22 AM   #239
lil-bump's Avatar
Default mega 2607 pipe and header
I recently mounted this pipe(Mega-2607) to my MTX-4. But the shape of the header positions my pipe too far away from the chassis. My pipe and springs take a beating being so far away from the chassis. Is there a different syle header that keeps the pipe closer to the chassis.
Old 07-14-2007, 10:12 PM   #240
charlesd's Avatar
Quick question,
I'm in the market for a new engine and saw the spec 2 at 150$. (i'm on a budget).
I'm using an sts d3r and it's quite dead now after 2 seasons. How does the spec 2 compare to the sts d3r? If not comparable to a d3r, what other engine would you compare it to?
charlesd is offline   Reply With Quote
Nitro Motors Clearance RC2Xtreme R/C Items: For Sale/Trade 0 01-15-2006 01:32 PM
Two nitro motors....MUST SELL racer_RR R/C Items: For Sale/Trade 3 08-26-2004 01:41 PM
Two Nitro motors for sale. John Fontaine R/C Items: For Sale/Trade 26 03-26-2004 03:53 PM
Old Nitro Motors John Q Onroad Nitro Engine Zone 2 03-17-2004 04:26 PM
Nitro Motors cnitro R/C Items: For Sale/Trade 0 03-12-2004 06:53 AM
