Old 11-20-2005, 03:06 AM   #91
burito's Avatar
@sedanfahrer: very well done
@bundy-bear: the lrp z.12r comes with 2 different sized exhaust rubbers to accomodate all types of exhausts. I've personally used Picco, Novarossi, TM and Mielke pipes with no problems whatsoever.
Reto Koenig
burito is offline   Reply With Quote
Old 11-20-2005, 04:12 AM   #92
B4
B4's Avatar
I sent Bundy-bear a PM saying almost the same thing.
Burito can you please me tell does the crankshaft have different timing in the Spec2 motor.
B4 is offline   Reply With Quote
Old 11-20-2005, 06:01 AM   #93
burito's Avatar
Yes, timing of the crank is different but it's interchangeable with the old crank.
Same goes for the liner, piston and combustion chamber! All different but interchangeable (not with eachother of course as a mix, but as a general replacement).
Reto Koenig
Old 12-13-2005, 02:40 AM   #94
prg
Default lrp z12r tuning
Just ran my new lrp spec 2 in our local club race.. g8 motor.
Kept it quite rich on the top end 5.5 turnd out but when it got warm.. after 5 min of running it started 2 sound lean (revs staying up) as i backed off for a corner. i think the bottom end needle was around 5 out. Could i have this wrong in that the bottom end should be much richer and top could be leaned alittle more.
using 16 % fuel.
Any help would be apprieciated
prg is offline   Reply With Quote
Old 12-13-2005, 02:54 AM   #95
MrC
@prg;
Yes, try to richen to bottom end needle.
In general, if the engine does not keep itīs tune and starts to lean out after a few minutes of racing, the bottom end needle needs to be richened. That happens quite often and it is always the first thing, what I ceck, when tuning the engine.
You tend to lean out the bottom end during static setup of the carburetor. In most cases, the engine has not warmed up completely (including chassis and all other aluminum parts) thus it is changing its tune during driving.
If the engine is still cold or it was only warmed up in the pits, then I usually set the bottom end a tiny bit too rich in order to compensate the above behaviour.
Hope that helps.
Best regards,
Andy
MrC is offline   Reply With Quote
Old 12-13-2005, 03:00 AM   #96
Hesky's Avatar
I think maybe if you tune the motor with around half a tank or less, with the engine completely upto temp you may find the engine holds a tune better.
Hesky is offline   Reply With Quote
Old 12-13-2005, 05:13 AM   #97
prg
Default lrp engine tune
Thanks for your help..
It was a hot day with air temp in mid 30's so during the race we tried to richen the top end however the motor flamed out as i exited the pits. set it back to where it was and re started. I did read in previous msg's that they may perform better with a richer bottom end
Old 01-10-2006, 05:57 AM   #98
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Burito,
Can you talk a little about the .18S Pro engine ? ... i need references for a couple of guys who race small block monster trucks (Revo's and Tamiya TNX's) ... would be a good contender v/s .18 TM, and .18 TZ's ? ...
thanks in advance,
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 01-10-2006, 06:07 AM   #99
burito's Avatar
LRP Z.18S Pro engine is side-exhaust, I think you're looking for a rear exhaust race engine. right?
Reto Koenig
Old 01-10-2006, 11:27 AM   #100
Tabushi's Avatar
The .18 its side exhaust, so its a direct fit on a Tamiya TNX PRO right ? ...
I need to get maximum info about this engine ...
thanks,
Pat
Old 01-10-2006, 01:20 PM   #101
burito's Avatar
Check our new product section first, which you find here: http://www.lrp-electronic.de/e/lis/
Let me know if you'll have any additional questions.
Reto Koenig
Old 01-10-2006, 03:42 PM   #102
Tabushi's Avatar
Thanks for the link ... i think that the .18 engine its what i need ... but i do need SLEEVE carburator, and ou have just barrel one ...
Old 01-11-2006, 01:18 AM   #103
burito's Avatar
You can use the slide carburator from the Z.12R Race (not Team!) on the Z.18S Pro, that will work and it's not an expensive item.
Reto Koenig
Old 02-01-2006, 08:41 AM   #104
afiq's Avatar
Hai Reto!! any performance LRP pipe product coming out?.Still 5mm is the best especially during final,my refueling is 8 min.Any suggestion to increace acceleration?Top speed really fast.Any tip centax adjustment for mtx4?Thanks Reto,
afiq is offline   Reply With Quote
Old 02-01-2006, 11:23 AM   #105
MrC
Hi afiq,
Iīm not Reto, but I think I can help you aswell.
As a matter of fact, we are in the final stages for a new LRP 1/10 Competition pipe including a proper manifold. The pipe is finished, but we still need to do some tweaks to the manifold.
We are aiming on April as official release date.
To get more bottom end power, try to richen the bottom end needle about 1/4 to 1/2 of a turn. If this doesnīt help, try to get your hands on a Picco 2607 pipe incl. conical header. This is the one we have been using the whole season and it fits perfectly to the timing of the Z.12R engine.
Cheers
Andy
Nitro Motors Clearance RC2Xtreme R/C Items: For Sale/Trade 0 01-15-2006 01:32 PM
Two nitro motors....MUST SELL racer_RR R/C Items: For Sale/Trade 3 08-26-2004 01:41 PM
Two Nitro motors for sale. John Fontaine R/C Items: For Sale/Trade 26 03-26-2004 03:53 PM
Old Nitro Motors John Q Onroad Nitro Engine Zone 2 03-17-2004 04:26 PM
Nitro Motors cnitro R/C Items: For Sale/Trade 0 03-12-2004 06:53 AM
