Dual plug head buttons
Old 08-18-2009 | 06:49 AM
Default Dual plug head buttons
Well I know this is an all on-road engine forum but I thought I'd share my new dual turbo button for my drag race engines. So far the dual plug has definately allowed for more fuel to be added and the engines have run quicker and faster over using my standard buttons that come with the engines. The kicker is my Traxxas 3.3 and 2.5R engines that run with the big boy engines all day and used be laughed at but only after the performance is that they got some respect.
Anyways, just sharing.
Brent Davis is offline
Old 08-18-2009 | 11:54 AM
nazwenhome's Avatar
looks very promising mind sharing the consumption before and after? angle between two plugs?
thanks
nazwenhome is offline
Old 08-18-2009 | 02:38 PM
lil-bump's Avatar
Which one gets the glow ignigtor to start the engine. how is the second one fired.
lil-bump is offline
Old 08-18-2009 | 02:54 PM
Roelof's Avatar
When the motor is started up with one plug glowing the other plug will come alive bij the combustion.
Roelof is offline
Old 08-18-2009 | 04:23 PM
wingracer's Avatar
Nice looking work. Are you using turbo plugs or standard?
wingracer is offline
Old 08-18-2009 | 04:32 PM
helivaguy's Avatar
wow nice work but now the chance of dropping a coil down the engine doubles
helivaguy is offline
Old 08-18-2009 | 05:35 PM
Thanks all.
The heads all use turbo plugs. There was no need to do standard plugs with having these made up.
You are correct in basically just glow one plug and start the engine and the other plug will glow up but for those that wanna make sure that the plug is glowing, just simply touch that plug with your igniter and go. There is a sound difference from using the standard head button and then the dual buttons which want more fuel once it is running.
Old 08-18-2009 | 06:17 PM
lil-bump's Avatar
Originally Posted by Brent Davis
Thanks all.
That is truly amazing. Get a patent; some company will try to copy it.
lil-bump is offline
Old 08-18-2009 | 07:54 PM
Thanks all.
That was what we used to do with the CMB marine engines, Ran dual plugs and when the engine was running just tapped the 2nd plug and you would hear a difference. Never before a car but hey looks good!!!!
xspower is offline
Old 08-18-2009 | 07:58 PM
wingracer's Avatar
Ah ha, I knew I had seen it somewhere before. I saw a CMB boat motor set up like that. Thanks for reminding me
Old 08-19-2009 | 09:16 AM
yes the CBM head had already been converted and used by us but the fuel burn room is not that great and it is too deep. The design that I have now has sorta two burn rooms for the plugs and isn't killing your compression ratio.
Here's the CBM heads.
Old 08-19-2009 | 02:16 PM
Why not , real cars have done that for decades . My race dirt bikes had it, heck , even my '81 Datsun had it.
spooky 1 is offline
