NOVAROSSI 353 RACE 09 OR 3SCT??
I am just trying to decide on another engine I have a nova 3sct tune already and they are fast but the new 09 353 race is also on the cards , I race on small fairly tight tracks should I stick with the 3sct?
cheers
cheers
u can try 353 on a small track.its fast too. imho its not worth it, need to change to a longer pipe, need to change higher ratios and increase clutch spring tension. the worse part, it need overall new chassis setup.
just my 2 cents on this....I have both those engines and found the the Max RR3 was a better choice. Running a small tight track, putting the power down from 3sct and the 353 was harder with the power curve they have. The RR3 seems to have a smoother power curve, and with running a lower gear on the NT1, 15/59-20/54 and a 2602 pipe,made it almost impossible to catch.
***ran on a parking lot track at Supperior Hobbies***
track size is "about" 60ftx120ft (20x40 meters)
car setup is posted at http://forum.teamxray.com/xform/inde...1162&setup=nt1
thanks for the responses guys but I went the 353 and ran it last night, theres not much difference between the 3sct and 353 there is plenty of punch, and I did notice a cooler temp on the 353?? thats running on a 260 4 fin header.
cheers
cheers
