Like Tree1Likes
Palmaris engine thread
Old 10-25-2005 | 08:37 AM
  #2026
stefan's Avatar
Edward,
Mielke has a new manufacturing system that they call "SNAP" (Spezial New Alu Procedure for harder und thinner material)
You can find the info on their website.
The surface of their pipes is available with a chrome layer, which makes it very easy to keep the pipe looking likenew for a long time.
stefan is offline
Old 10-25-2005 | 09:15 AM
  #2027
EdwardN's Avatar
Originally Posted by stefan
Edward,
Thanks Stefan.
By the way, this is one looks like pipe we used.
Edward
EdwardN is offline
Old 10-25-2005 | 11:11 AM
  #2028
stefan's Avatar
Yep, that's what I'm using as well. You need to try it with the long conical header.
stefan is offline
Old 10-25-2005 | 12:02 PM
  #2029
burito's Avatar
have you tried the Mielke 2501 with the long conical header?
Makes awesome power with my engines.
With the short header it does not have a lot of torque, that's right.
I did try the 2501 several times, I can't remember about the header tough. I did use it the way Mielke sent it to me and I always had better experience with the Picco 2607 or the Nova 2601/02.
Mielke made several updates to his pipes, so the same EFRA number doesn't necessarily have to be the exact same spec all the time as far as I can see. Pretty weird, but this seems to be the case.
He does make quality stuff, but so far I never liked them with my engines.
burito is offline
Old 10-25-2005 | 12:30 PM
  #2030
stefan's Avatar
Reto,
the current 2501 (got mine from Daniel in Austria) comes with the short header, which makes real good top end but is only suited to the biggest tracks. Mine really came alive when I put the long header on it for our regular, medium size tracks. First time out, I missed all my brake nad turn in points, compared to the RDL Turbo II pipe, which is also noc slouch.
stefan is offline
Old 10-25-2005 | 12:57 PM
  #2031
afm's Avatar
afm
Current M Mielke pipes and headers
MM1900 Pipe Set (w/90° manifold, spring & gasket ), black EFRA 2501
MM1900P Pipe Set (w/90° manifold, spring & gasket ), Chrome EFRA 2501
MM1903 Std. manifold 90°,springs,gasket ring for Set 1900, black
MM1903P Std. manifold 90°,springs,gasket ring for Set 1900P, Chrome
MM1904 Manifold same as MM1903 only 5mm longer, black
MM1904P Manifold same as MM1903P only 5mm longer, Chrome
MM1905 Manifold same as MM1903 only 10mm longer, black
MM1905P Manifold same as MM1903P only 10mm longer, Chrome
AFM
afm is offline
Old 10-25-2005 | 02:30 PM
  #2032
stefan's Avatar
1900P with header 1905P
stefan is offline
Old 10-27-2005 | 09:14 PM
  #2033
EdwardN's Avatar
Hi guys.
Batch arrived and now it is complete engine (carb included).
Here are some pics of it.
Edward
Attached Thumbnails Palmaris engine thread-s3700039.jpg   Palmaris engine thread-s3700040.jpg
EdwardN is offline
Old 10-27-2005 | 09:17 PM
  #2034
kitracer's Avatar
Originally Posted by EdwardN
Hi guys.
Edward
Wow, this time arrive fast...
send send send.. hurry
kitracer is offline
Old 10-27-2005 | 09:38 PM
  #2035
Default Nitro and Clearance?
Can you please tell me the shim setup for 16% Nitro fuel on the PR12.
I assume std. is for 30%
C Mike Hunt is offline
Old 10-28-2005 | 04:32 AM
  #2036
n.e.r.d's Avatar
Default pricing?
hi palmaris,
may i know what's the pricing on the profi pr.12 in HKG$?
i'm from singapore and looking to get a .12 engine soon.
thanks in advance!
n.e.r.d is offline
Old 10-28-2005 | 05:33 AM
  #2037
EdwardN's Avatar
Hi Mike.
Yes, motor comes for 30% Nitro and it has total shimmng .4 mm. For 16% Nitro I will sugest .25mm. Our shimming has possabilities to adjust by .05 increaments-copper shims there is .05 mm.
Edward
EdwardN is offline
Old 10-28-2005 | 05:36 AM
  #2038
EdwardN's Avatar
Originally Posted by n.e.r.d
hi palmaris,
thanks in advance!
Hi N.E.R.D
In this forume we are not allow talking about salling., sorry about it. To know pricig please send PM to Kitracer-he is destributor for Asia, or please visit our web site to obtain email adresses for service www.palmarisracing.com
Edward
EdwardN is offline
Old 10-28-2005 | 06:15 AM
  #2039
Looks great Eduard!
Surge is offline
Old 10-28-2005 | 06:16 AM
  #2040
EdwardN's Avatar
Hi Guys.
I want to answer on some questions which I recievd over PM and emails.
Motor is 12 gramms lighter then Novarossi based motors, and most of weight we try to remove from cooling head. We use AL alloy which has better heat dessipiation then normaly used alloys. It has mounting sizes exactly the same as any other .12 size motors, so it is not reqiered any modifications for car.
Cranck is 12 mm and it has different ballancing compare to other brands which is helping us to get as much power as we can, specialy on top end.
Some parts are interchangable with Novarossi and STS based motors. Carb is leagal.
Porting inside the motor is our development and they are different from any other brands, as well as porting on sleeve. Further modification on sleeve will hirt performance and we strongly recomend to do net modify any parts in engine-on p/l set it will change flow and on the cranck it will chnge balancing-unless you are absolutly know what are you doing. Removing 0.1 gramm on wrong palce on cranck will change balancing tramendosly.
I guess I answer all most FAQ, but if anybody have more questions, please feel free to ask.
Edward
EdwardN is offline
