Palmaris engine thread
#1878
Originally Posted by stefan
Hey Edward, any news on your European distribution, or does everything stay the way it was?
Thx,
Stefan
Thx,
Stefan
I replay on your last email next day I recieved it, but there was no more inquieries. Please check my last email.
Edward
#1880
Originally Posted by kitracer
For Thailand, I used 0.4mm (0.3 , the wire pushed in really bad)
I agree with RayJ on the shimming and his numbers. Number and thickness of shims does not automatically result a sure head clearance number especially from one Nova engine to another...
In Thailand early this year, my NovaMax was running with 2 x 0.1 mm copper shims with the supplied 25% Tornado fuel. I used the 7tf plug. That translated to about 0.5 mm head clearance upon measuring and I was getting about 120 degree C during race condition.
#1881
Yes, even an engine with same model has different TDC clearance. In this case, I found Novamax is probably the worst because I've experienced over 4 engines (P and S series) each of them is different. 2 engines has 0.05 and others are 0.25-0.3 mm
#1882
weeeeeeeeeeeee,
whats up.
True, I experienced the same thing on different Nova' crankcase ( not as bad as daiz24 exp
) but 0.3 or 0.4mm head shim is easy and good to start with for 25 to 30%. But read plug and go as low as possible (within limit) to achieve the best result.
Also exhaust make some difference.
whats up.
) but 0.3 or 0.4mm head shim is easy and good to start with for 25 to 30%. But read plug and go as low as possible (within limit) to achieve the best result. Also exhaust make some difference.
Originally Posted by InitialD
Hey Chris, I'm clearing some backlog here and reading some old stuff...
#1887
Originally Posted by Pyramid
just only because you (or dare to say it JP) is not around
1Likes
