Kyosho X312T engine
Old 12-14-2009 | 01:49 AM
  #31
GREGORY!'s Avatar
Originally Posted by pistonhead
Cool.
how much clutch gap are you using?
Because i am hearing a lot of 0.5mm clutch gaps with these engines.
pistonhead like i said before.go to that link.it has many many things to look.
a lot of information!
from clutch settings,gearing,shimming,needle settings.
just everything.
GREGORY! is offline
Old 12-15-2009 | 02:51 AM
  #32
pistonhead's Avatar
ok man
pistonhead is offline
Old 12-15-2009 | 02:53 AM
  #33
pistonhead's Avatar
Beauty!
Old 12-16-2009 | 06:30 PM
  #34
pistonhead's Avatar
where are you guys getting the glowplug for this engine.
the CRF88836 X312T CRF turbo X-plug No.6
Don't know where to get it from.
Old 12-16-2009 | 09:45 PM
  #35
jca2000au's Avatar
Young Pistonhead,
use O.S. P6 or P7, i will have some with me this sunday.
jca2000au is offline
Old 12-16-2009 | 11:31 PM
  #36
MikaR's Avatar
Just one example
http://www.rcmart.com/catalog/rc-glo...6-p-20152.html
MikaR is offline
Old 12-17-2009 | 09:04 PM
  #37
pistonhead's Avatar
Originally Posted by jca2000au
Young Pistonhead,
thanks, i didn't know the os would fit
i can get the OS P6 turbo plugs from RC hobbies near me.
Cheers.
can i use
Team Orion 06-T Glow Plug Turbo Medium
[88811]
Old 12-23-2009 | 03:58 PM
  #38
pistonhead's Avatar
how hot are you guys running this engine
Old 01-10-2010 | 03:13 PM
  #39
Anyone had a crank pin failure on these? I broke my pin today..
chovden is offline
Old 01-10-2010 | 10:08 PM
  #40
i have, conrod punched a hole in the case also
elche_83 is offline
Old 01-11-2010 | 01:49 PM
  #41
On mine to crank, conrod and block is gone...
Never run hot maks I have had is around 120C, ran about 185F when it let go on sunday, has just under 3 gallons on the engine and was still very strong and good
chovden is offline
Old 01-11-2010 | 10:58 PM
  #42
could have been anything that caused it a bad bearing,slighty sloppy con rod the crank pins carry quite a bit of load in rotation mass when you think about and these engine rev hard to,guess we had bad luck on to the next engine mate.
elche_83 is offline
Old 03-17-2010 | 07:01 PM
  #43
pistonhead's Avatar
i havn't had any problems with my engine so far.
it is not bad at all. had mine for about 10 months.
it may not be the fastest engine out there, but it is the most reliabe engine by far. the easyest engine to use.
it almost starts before it hits the starter. ha ha
