Kyosho X312T engine
I just got the X312T engine and i am wondering if you have to heat the engine up with a heat gun/hair dryer before starting it for the first few tanks.
It says that because of the unique CRF technology you only need to run it in for 2-4 tanks. Do i still need to heat it before starting? |
Originally Posted by pistonhead
(Post 5775598)
Originally Posted by Riketsu
(Post 5775606)
I would always recommend to pre-heat an engine before starting it up. Be it CRF, Picco or Novarossi. It helps the rod maintain its life since your reducing the stresses created on it.
You don't need to heat up the engine before breaking it in.
Just run it rich for a couple of tanks and make it leaner so that it starts to have power after 3-4 tanks. After that, start fine tuning to get max power. The pinch at the top is normal. |
Originally Posted by Nano
(Post 5775991)
(Post 5776036)
But with this one it gets hard when the top of the piston is level with the top of the exhaust port. won't it damage it?
(Post 5776048)
The pinch is always at the top it's normal.
cheers alex |
hi, run my X312T for the 1st time last Sunday, it was fantastic. This is Kyosho version with goldish head. Can't compare much powerwise but based on what I've seen our local track, comparing, I wasn't any slower. This engine seemed so easy to use, let's see how long it will last.. Thumbs up so far!
Thanks for all the help guys!
What glow plugs are you using?
Originally Posted by Bundy_Bear
(Post 5954483)
I think the one that comes with the engine is an Orion REV plug (medium #6)
I've been using the cold REV plug lately with 16% nitro |
X312T Performance
So how are these engines performing? I really like the look of them and am seriously considering this as my next engine.
Let the feedback roll in |
Opinions anyone?
engine
lots of rev's in this motor , need perfect clutch setting and under gearing to get power to the ground. if your running on a small track i wouldnt get this if ur running on a big track go for it. there are better promising engines for the few extra$. each to there own.
| All times are GMT -7. It is currently 12:22 AM. |
