Kyosho X312T engine
Old 08-29-2009 | 01:52 AM
  #16
Roelof's Avatar
The only reason not to go for that engine is that it isn't produced anymore so parts will be difficult to find. If you can find the right setup in clutch and gearing it will run fast,
Roelof is offline
Old 08-29-2009 | 03:34 AM
  #17
Alex Siddique's Avatar
bartz rc part have them on special in sydney and lots of spare.
Alex Siddique is offline
Old 08-29-2009 | 04:27 AM
  #18
mtbkym01's Avatar
The price at Bartz is what has me interested
mtbkym01 is offline
Old 08-29-2009 | 04:57 AM
  #19
Default Carb Issues
I found that an OS carb is a perfect fit and will make the crf an easy to tune engine. I put a carb from an 18 tz on mine and it's fast but not legal if you must run a carb with a 5.5 opening. Maybe a carb from a speed 12 would work also.
latemodel13 is offline
Old 08-29-2009 | 07:18 AM
  #20
cheROK1212's Avatar
Default manpipe
What pipe mani combo is good for these engines if you can't find the CRF pipe? Anything tuned for high RPM?
cheROK1212 is offline
Old 09-08-2009 | 02:31 AM
  #21
skyline v12 plus is very torquey pipe for crf . but makes the engine run a bit hotter .
Old 12-06-2009 | 11:14 PM
  #22
pistonhead's Avatar
Thanks for all the info guys.
i have been running this engine for about 6 months and it is awesome!
So easy to tune!
Its FAST!
Reliable!
Best engine i've ever had.
pistonhead is offline
Old 12-06-2009 | 11:19 PM
  #23
pistonhead's Avatar
Oh and if anyone has some info on clutch set up for this engine i would like to hear it.
thanks.
Old 12-07-2009 | 01:17 AM
  #24
GREGORY!'s Avatar
thanks.
go here!
you will find everything you need!
http://www.rctech.net/forum/exclusiv...o-results.html
GREGORY! is offline
Old 12-07-2009 | 02:19 AM
  #25
MikaR's Avatar
thanks.
Hi, I'm not a racer (yet) in this class but I've been using the 3D clutch from Kyosho with my RRR and seems to work perfectly fine. Thanks
MikaR is offline
Old 12-12-2009 | 03:58 PM
  #26
pistonhead's Avatar
And you are using the Kyosho CRF X312T engine?
Old 12-13-2009 | 04:23 AM
  #27
I found the veg clutch weights,shoe and spring works well But I think they only fit kyosho clutches
elche_83 is offline
Old 12-13-2009 | 11:05 AM
  #28
MikaR's Avatar
So far yes. Now also have the newer Orion CRF .12 waiting for the next season 2010 with RRR 2D clutch.
MikaR is offline
Old 12-13-2009 | 03:12 PM
  #29
pistonhead's Avatar
Cool.
how much clutch gap are you using?
Because i am hearing a lot of 0.5mm clutch gaps with these engines.
Old 12-13-2009 | 10:00 PM
  #30
MikaR's Avatar
~1.1 - 1.2 mm in the clutch nut. ~0.5mm play in the end of the cranck (the locking screw).
MikaR is offline
