Like Tree195Likes
Novarossi engines thread
Old 04-04-2021 | 02:02 PM
  #6031
bboy's Avatar
I also have a similar concern about picking up another Nova engine, actually a Max engine.
My last two were Max but since they are Nova based, I am not sure if I should continue getting them as I am going to need a new one soon...
bboy is offline
Old 04-04-2021 | 02:52 PM
  #6032
Roelof's Avatar
Max has his own full production line and does not need to rely on Novarossi.
Roelof is offline
Old 04-04-2021 | 05:59 PM
  #6033
bboy's Avatar
Got it, thanks! didn't know this.
bboy is offline
Old 04-05-2021 | 02:31 AM
  #6034
Originally Posted by kawasaki161
Piston + Liner, could also be called Piston + Sleeve or Piston + Cylinder if you really feel like it, people will know what you mean.
Not quite sure if I agree on 5% driving + 95% tech statement though. Sure it's important to know your chassis + engine setup and it's easy to make gains with that early on. But quality track time where you're focusing on improving your driving is invaluable once you've run out of things you can blame on the car
Oh haha - thanks for the lingo tip... Yeah perhaps i should clarify what i mean by the 5% -not in terms of lap time but perhaps 95/5 in terms of time spent tinkering vs actually driving (at least for me) - but then again it did take me almost 40 mins to replace a front belt the other day when i'm sure others would have had it done in 5-10mins).
hannhann00 is offline
Old 04-08-2021 | 02:17 PM
  #6035
sinisterRC's Avatar
Hello,
So I was servicing my Mephisto and noticed two of the crank weights were loose, one actually fell out. Has anyone had this happen before? Can I run it without the weights?
Thanks!!
sinisterRC is offline
Old 04-08-2021 | 05:13 PM
  #6036
choisan's Avatar
i won't use it for sure.
choisan is online now
Old 04-08-2021 | 10:11 PM
  #6037
Originally Posted by sinisterRC
Hello,
Thanks!!
I have 3x mephisto and none of them have that problem.
Do you have any pictures?
GeorgeCk is offline
Old 04-09-2021 | 12:42 AM
  #6038
Roelof's Avatar
I had it with a 35plus21 with one of the 2 inserts
I would sugest to use a glueing loctite like 648 to put it back
Roelof is offline
Old 04-12-2021 | 06:03 AM
  #6039
BigC2007's Avatar
Default R7 conrod ?
Hey Gents
Don't know if this has been ask yet if so forgive me but is there alternative conrod that can be used for a long stroke .21 ?
BigC2007 is offline
Old 04-12-2021 | 06:58 AM
  #6040
choisan's Avatar
i guess max is selling the same r7 alike conrod
Old 04-12-2021 | 07:08 AM
  #6041
BigC2007's Avatar
Thanks choisan
choisan likes this.
BigC2007 is offline
Old 04-12-2021 | 07:53 AM
  #6042
Roelof's Avatar
MAX his latest engines use rods which are made by Hudy. All I know they have a 4.8mm crankpin, not sure if the length is the same.
Roelof is offline
Old 04-12-2021 | 07:57 AM
  #6043
BigC2007's Avatar
Thanks Roelof
BigC2007 is offline
Old 04-12-2021 | 08:34 AM
  #6044
sinisterRC's Avatar
That's exactly what I did (plus some holy water on the heat sink lol) and it lasted through this past race weekend. Have to take it apart and inspect it.
The weights only move towards the bearing side not towards the rod because of the concave hole they are slotted into.
Old 04-12-2021 | 01:48 PM
  #6045
sinisterRC's Avatar
You can see the weight all the way to the right was out, the middle weight also was loose.
