Like Tree195Likes
Novarossi engines thread
Old 04-05-2018 | 06:37 PM
  #5581
GMartinez's Avatar
Originally Posted by sinisterRC
Question fellas, I have .21 Flash on a MRX6. What fuel would you recommend? I'm in Miami, FL which means its almost always hot. Thanks for the help!
Runner time Desoto Racing.com
Maxima RcTarget.com
sinisterRC and Serpent-Dan like this.
GMartinez is offline
Old 04-09-2018 | 12:18 PM
  #5582
yxiaocheng's Avatar
Looking for a second .21 engine for 1/8 onroad. Already have a Flash. Which one should I get? What is the Mito 9 ON “C”?
yxiaocheng is offline
Old 04-09-2018 | 01:22 PM
  #5583
Roelof's Avatar
The Mito on 9C is basically a Flash
Roelof is online now
Old 04-11-2018 | 06:58 AM
  #5584
sinisterRC's Avatar
Maxima RcTarget.com
Thanks, what % nitro should I break in the engine with? 30?
sinisterRC is offline
Old 04-12-2018 | 12:25 AM
  #5585
ralphierace13's Avatar
25% .21 motors come shimmed for 25% and that's how u should leave it...
ralphierace13 is offline
Old 04-12-2018 | 01:05 AM
  #5586
It would be best to read the manual that comes with your engine. Some engines are setup for 25% Nitro, where others are setup for 16% or even a range. But if your engine is from a reputable manufacturer, their manual should state what nitromethane and oil contents the engine should be used with.
davidl likes this.
RCTecher12 is offline
Old 04-30-2018 | 07:08 AM
  #5587
vernon7026's Avatar
Default I
I found a good deal on a nova 21 keep on long stroke ?
are these good engines ??
thanks
vernon7026 is offline
Old 04-30-2018 | 08:52 AM
  #5588
Roelof's Avatar
And this question you allready had started in a new topic, no need to ask again.
The keep on is an outdatet engine but still good enough. It was one of the 1st extra long stroke top models from Novarossi probably as a follower to the succes of the Picco extra long stroke. But it was not a populair engine with many drivers, on several races drivers did switch back to ther Flash as we see today that the normal long stroke models like the Mito 35wc is their topmodel
But if you are no toplevel driver then you will have a good and fast running engine.
Old 04-30-2018 | 10:08 AM
  #5589
vernon7026's Avatar
No deffo not a top level driver ! Just want a decent motor to start off, although maybe I should mention I have a xceed 21 and Sirio 21
Old 05-02-2018 | 06:21 PM
  #5590
ogreasurada's Avatar
Silver head on Kurzbuch's car. New 21 model coming out soon?
ogreasurada is offline
Old 05-02-2018 | 11:27 PM
  #5591
Roelof's Avatar
I was told he swapped from engine supplier.
Old 05-03-2018 | 03:33 AM
  #5592
He has also used a Novarossi with this color on his head
He said it was a Novarossi engine
Pedro Jesus is offline
Old 05-03-2018 | 09:50 PM
  #5593
Roelof's Avatar
Yes, was forgetting to correct it yesterday but I had a chance to look at his car and indeed a blank head with the Novarossi logo on it. It looked like it had thicker cooling ribs on top. I'll try to make a photo of it but probably REDRC will have a chassis focus as well.
Old 05-04-2018 | 07:22 AM
  #5594
sinisterRC's Avatar
Hello,
I have a Nova Rossi Flash .21 PT/A. I had to move the intake nipple to fit my application (MRX6). I know this nipple has two tiny hole inside, do those need to be aligned with the high speed needle? Also I noticed I could twist my carb manually, how tight should it be on the engine case?
Old 05-05-2018 | 01:24 PM
  #5595
Maybe only evolution on head or new evolution Mito35 WC?? 2019 edition??
http://ens.redrc.net/wp-content/uplo.../sa_simon3.jpg
http://ens.redrc.net/wp-content/uplo.../sa_simon2.jpg
http://ens.redrc.net/wp-content/uplo.../fr_simon6.jpg
