Like Tree195Likes
Novarossi engines thread
Old 11-07-2017 | 08:40 PM
  #5431
dan_vector's Avatar
Originally Posted by ralphierace13
I tried the ones recommended for my mito and was same shit for a month in the beginning of the summer went throu like 10 of them went to os used the same plug for the next 3 months lol!!! I swear !!
You must've been using the old C8TGF or C8TGT plugs which I agree weren't the best. They were ok just a bit fragile and if you were even 1/8 turn too lean it'll break the element. The CT series are much MUCH better. Give one a try and you'll see what I mean.
dan_vector is offline
Old 11-07-2017 | 08:42 PM
  #5432
dan_vector's Avatar
Originally Posted by implusepro
what OS plug are you running in your mito 21?
is it novarossi ct8 = os rp8?
thanks.
The CT series plugs are quite different however the old Novarossi C7TGF or a C7TGT was comparable to the OS RP7. Those who ran OS plugs (including myself) usually ran RP7's.
Old 11-18-2017 | 12:28 PM
  #5433
AutoRCnewsModelisme - Novarossi Mito 7 On Road
AutoRCnewsModelisme - Novarossi Mito 9 On Road
Pedro Jesus is offline
Old 11-19-2017 | 01:47 AM
  #5434
dan_vector's Avatar
Both of these are 2015 old models and discontinued. Replaced with the Mito WC.
Old 11-19-2017 | 02:52 AM
  #5435
But Mito 9 is still in production
Even though an engine was launched in 2015.
Old 11-19-2017 | 09:06 AM
  #5436
dan_vector's Avatar
It isn't in production anymore. The WC35-WCA and WC35-WCH/17 are the current production onroad 21's. Just interested why post an article from 2015
Old 12-06-2017 | 08:46 AM
  #5437
petersen114's Avatar
Opinions on the Nova Ison 21 GT. Thinking about getting one.
petersen114 is offline
Old 12-06-2017 | 04:40 PM
  #5438
Ran this engine at the Toledo track for the last 3 years. It has very good bottom end torque so it is useable in a wider range of clutch settings. Missed TQ in the Master 1/8 class by .75 seconds in 2015.
petersen114 likes this.
davidl is offline
Old 12-06-2017 | 11:08 PM
  #5439
dan_vector's Avatar
The engine is very good. I ran one for a while successfully. It's now my wet weather engine and I run the Mito GT5/17 which is fantastic and has a broader power band than the ISON.
Old 12-08-2017 | 12:15 PM
  #5440
bluer322's Avatar
Quick question about how fuel does it take break in a novarossi motor
bluer322 is offline
Old 12-10-2017 | 01:12 AM
  #5441
Varies depending on ultimately how much pinch the engine and liner have.
Generally speaking 2 litres until it can be tuned for some power on track...5 litres until it starts making real power.
jtrmx250 is offline
Old 12-11-2017 | 04:08 AM
  #5442
ralphierace13's Avatar
its funny I take time to break in my race motors right, but I buy a lot of traxxes nitro off road trucks just to play outside and I start them brand new and just abuse them from the start and the motors run great never have a problem lol just find it funny
ralphierace13 is offline
Old 12-11-2017 | 09:27 AM
  #5443
Not sure it is good to compare the NR engines with those from TRAXXAS. I worked at a hobby shop for 7+ years, partly doing repairs on nitro cars. And it mostly involved TRAXXAS. I found their combination of engine timing, head clearance and carb bore as very optimum for the beginner/basher. They went through a period where the engines had a lot of taper in the liner. Those engines failed much more frequently that those that followed with shallow taper. Also, if you used the TRAXXAS 30% fuel, the fail rate went up dramatically. That is because the novice drivers didn't know how to tune when the combustion chamber was too small.
Looking at the NR engines, they are using a ton of liner taper compared to the other engine manufacturers. That means that much more care and a solid process must be used during break-in. So my recommendation is to be very patient with the NR engines during break-in. It will take a little more time to get the engine ready for racing. And remember that some engines will continue to get better after you run them for another 10 tanks than you would have thought. And "after-run" lubrication is your friend for all engines. Have fun.
Pedro Jesus likes this.
davidl is offline
Old 12-11-2017 | 05:43 PM
  #5444
I'm not trying to compare them I'm just saying I never had any problems with Traxxas motors also never used there fuel always my race fuel and was always 30% but again never had a problem and some of them blew away my 8th scale lol, I don't really break in my race motors too much a few tanks and thsts it and I use one motor all season without a problem. I don't like after run oil I won't get into the details of y not but the fuels today's if u use a top quality u don't really need it just burn the fuel out and there will still be a nice coating...
Old 12-12-2017 | 11:21 PM
  #5445
The only risk you run when running new engines hard early relates to excessive heat. Either hot spots generate which can cause 'pickups' where the piston welds to the liner. This causes significant score lines on the piston - obviously not good.
Or you can just over heat the engine due to the friction generated by the high pinch.
To guard against heat you have to run the engine rich so it will not make good power...good power comes after a number of litres for nova.
davidl likes this.
jtrmx250 is offline
