Like Tree195Likes
Novarossi engines thread
Old 09-02-2006 | 10:17 AM
  #1621
thanks for advice
spent quite alot of time starting it, but starter box just doesnt spin the flywheel
the piston just gets stuck at the top of the sleeve and doesnt wana come down
im just gonna preheat it like mad next time, wasting my batteries for starter box
so is the secret just to pre heat it?
bigboss is offline
Old 09-02-2006 | 12:09 PM
  #1622
just tried starting it agen, still no luck
the flywheel spins, and wen i stop the starter box, the piston usually ends up right at the top of the head, meaniing the starter box wont budge the flywheel no more, which means i have to turn the flywheel by hand
i had 3 engines b4 this, all pull starts, just which i had a pullstart for break in
any other advice??
gonna try agen tomoz
bigboss is offline
Old 09-02-2006 | 03:51 PM
  #1623
ShermanSim's Avatar
Default nova rossi
Originally Posted by silverM3
I am interested in getting. Can you shed some light on your exp? how much is it? which shop has it for a good price? thx.
www.kamikazercracing.com
ShermanSim is offline
Old 09-02-2006 | 10:01 PM
  #1624
What is the best procedure to break in a microcast engine???
Rody is offline
Old 09-02-2006 | 10:35 PM
  #1625
RAD Dog Racing's Avatar
What is the difference between a short and a long #6 Turbo Novarossi plug.
RAD Dog Racing is offline
Old 09-03-2006 | 12:40 AM
  #1626
Chris West's Avatar
ive just broken in 3 novarossi engines for my 3 drivers for the worlds, 2 Plus 12-3CT Tuned's and a LLT3 Tuned and you dont need to pre-heat the engine, just push hard down on the starter box and dont back off so it turns over the engine and then put the ignighter on and let it idle for a tank, then drive it around the track rich as making it reach temps of 100*C and 110, towards the end of the 1 litre and man these engines are fast and we havent even tuned it for racing or put the runnertime race fuel that were gona use at the worlds,
Chris
Chris West is offline
Old 09-03-2006 | 02:57 AM
  #1627
wallyedmonds's Avatar
one tank on the box then put it on the track rich and slowly lean it up dont run on the box cuz this will wear out the piston,microcast pistons dont have alot of pinch just run it slowly rich and go into 2nd gear and lean it up after every tank.
wallyedmonds is offline
Old 09-03-2006 | 03:00 AM
  #1628
c is a hot plug f is a cold plug but the elm is the same
Old 09-03-2006 | 04:12 AM
  #1629
wohay!! finally got my engine started, now for the boring part of breaking in
bigboss is offline
Old 09-03-2006 | 01:22 PM
  #1630
spenzalii's Avatar
Good for you. Once you get that first tank thru, it becomes much easier to start. My NSr12 stripped the belt on my starter box trying to get it started that first tank. Once it got thru, it was much easier to start. Same ith my RB (although that didn't kill the starter box...)
spenzalii is offline
Old 09-03-2006 | 10:06 PM
  #1631
Chris West's Avatar
yeah so far the NSR12 has been the hardest to turn over for me when breaking in
Old 09-04-2006 | 04:26 AM
  #1632
I have just broke in a brand new nsr12 S5 on a breakin bench end after thr 3 tank it was very good (good compression and does not stuck at the top). Hovever, I notice a big gap on the shaft, I mean, I can move the shaft about 1mm in and out the engine. Is it normal? The engine seens to be very good, but I wil need to put some shims behind the flywheel to remove this huge gap....
regards
Eduardo
eduardo_garcia is offline
Old 09-04-2006 | 05:13 AM
  #1633
regards
Eduardo
NO DONT DO THAT its a fast motor leave it alone.
  #1634
LOL
Old 09-04-2006 | 06:15 AM
  #1635
I just got my Plus 21-C
Orfeous is offline
