NEW NOVAROSSI 2009 ENGINES
Old 06-03-2009 | 07:09 AM
  #121
Riketsu's Avatar
The 3 dots always face the exhaust. Some may find this crucial while others find it not important. I always used to mark my underheads so I would always sit them in the same direction.
Riketsu is offline
Old 06-04-2009 | 04:40 PM
  #122
BLKNOTCH's Avatar
Originally Posted by Nitro-Racer*
first of all the tuned version of an engine:
  • all parts are checked so there is the best fit between the parts(piston cylinder). they are choosen by hand
  • also when it says tuned it means that the crankshaft has been worked, and is now lighter since it is worked some metal is gone... and also the crankshaft "hole" is widened i think and there is also a better fuel flow since it is polished.
so in the end the tuned version is always better(meaning faster) than the "stock" version, but cant say that the stock version is not fast, its Very fast also.
Thank you for this answer, I am thinking to pick up 2 of the 353 08's as the pricing is super compaired to last year and I am running at a small to medium track so I am sure the none tuned version will be more then enough for what I am needing.
Sean
BLKNOTCH is offline
Old 06-07-2009 | 08:49 AM
  #123
spurgear's Avatar
What brand air filters u guys use on ur 353? I have the older plus 12-3CT and im using a unbranded non retail packaging air filter i bought from murnan many years ago and im finally out of it. It came in pairs with one bottle of oil. I want to change it because im having a problem with the foam unsticking after a couple uses. Any suggestions?
spurgear is offline
Old 06-07-2009 | 09:42 AM
  #124
Nitro-Racer*'s Avatar
emm no special suggestions i use the motorsaver air filter and anotherer one which is just the foam alone. you can also use the newer 1/10 scale ins boxes either from novarossi or rb
Nitro-Racer* is offline
Old 06-08-2009 | 09:16 AM
  #125
spurgear's Avatar
thanks anyone else?
spurgear is offline
Old 06-08-2009 | 09:15 PM
  #126
Mie3R's Avatar
after being out in the market for few months n so many races attended worldwide, whats the best tune pipe for this 353-09??
TQVM
Mie3R is offline
Old 06-08-2009 | 11:18 PM
  #127
TQVM
Novarossi 2652 with short conical header
seb1109 is offline
Old 06-10-2009 | 04:37 AM
  #128
Mazda614's Avatar
Originally Posted by stefan
The 2652 is a 3 chamber pipe which was developed for the new EFRA regulations which were supposed to come in effect this year.
Due to the horrible experiences 8th scale racers made last year with these 3 chamber pipes, EFRA postponed the introduction of these pipes indefinitely.
In other words, stay away from it.
The 2652 is a two chamber pipe, have a look at the Nova Site. The 3 chamber pipe is the 3501.
Mazda614 is offline
Old 06-10-2009 | 05:59 AM
  #129
musti72's Avatar
Is there anyone who had real experience with 2652?
musti72 is offline
Old 06-10-2009 | 06:03 AM
  #130
what are the differences in power delivery between a two and a three chamber pipe?
Old 06-11-2009 | 03:58 AM
  #131
Mazda614's Avatar
I'll let you know after our next club meet. I should have the pipe by this weekend.
Mazda614 is offline
Old 06-12-2009 | 04:54 PM
  #132
BLKNOTCH's Avatar
I ended up going with the 353 09 so I am very interested in the pipe question also. I am currently using the 2630 with great results but I am interested what is noted as best for the 09. I will be trying the 2620 also along with the 2601 as these are the 2 I am thinking to get otherwise I will just get another 2630.
BLKNOTCH is offline
Old 06-25-2009 | 01:25 AM
  #133
jt415gz's Avatar
Default Dual adjustment carb
Need help...
Flash .21 - What is the factory setting for the brass adjustment on the very opposite side of the low-needle... would it be flush with carb...or a certain amount of turns open from fully closed?
Also, what benefits do you get by adjusting it and how do you adjust it properly?
Novarrosi's FAQ mentions nothing about Double Adjustment Carb's only Single.
jt415gz is offline
Old 06-25-2009 | 04:35 AM
  #134
Roelof's Avatar
Originally Posted by jt415gz
Need help...
It positions the spraybar into the airflow, see it as a finetuning if you want (and can get) everything out of it.
Roelof is offline
Old 06-25-2009 | 08:32 AM
  #135
IQ0's Avatar
IQ0
Default Flash .21 Tuned
Any special advise on what need to do before, during & after break-in this 'fast & furious' engine?
..for info,..I have 35plus21..just after finished break-in (after 10 tanks), eng. compression was completely lost due to inside bearing seized..but once replaced by new bearing, eng. runs perfectly ok till now....just to add on here, I had never experienced lost of compression (after broken-in) on my other .12 engines.
IQ0 is offline
