MAX XXL3 .12 engine
Old 12-23-2008 | 06:53 AM
  #46
Osiris 75's Avatar
Originally Posted by Team Kamikaze
US$236.00 to US$314.75
Damn!!!
Osiris 75 is offline
Old 12-23-2008 | 07:23 AM
  #47
wingfloat's Avatar
Originally Posted by Novarossi
Some roasted potatos and carrots, abit of garlic, and back in the oven for another 20mins would of completed this!
do you sear the Kangaroo meat first?
wingfloat is offline
Old 12-23-2008 | 08:28 AM
  #48
Team Kamikaze's Avatar
Originally Posted by musti72
hmm... a jl3+2607 combo price
sam, why are you running JP/max instead of jl now?
As a shop, We have to run/test all engines, (we run what we sell) so I can give feedbacks to customers.
Team Kamikaze is offline
Old 12-23-2008 | 06:13 PM
  #49
between the jp first line pl3 and the max xxl3 is there a big enough diffence in power to warrant the price of the xxl3. I race at 301 raceway so alot of horsepower is always a big plus. Also how do these engines compare to the nova 353 tuned in the power department lowend, midrange, and top end.
HoboShop is offline
Old 12-23-2008 | 08:08 PM
  #50
The XXL3 is no doubt a very fast engine, it have power everywhere, the JP
P3L Modified in the hands of a good driver can give you a run for your money, it has good bottom punch and the mid range is on the mild side but have good top end, the 353 Tuned falls in between the 2.
Old 12-24-2008 | 03:39 PM
  #51
KWT-NITRO's Avatar
hi guys,
just got my XXL3 yesterday and i did the break in today.....First XXL3 to hit the track here in Kuwait.
i have a small question, i run 30% nitro fuel, shall i keep the shimming as from the factory? if not, how much should i add to run it safely with the 30% nitro, i did the break in without changing a thing....
cheers
Ali
KWT-NITRO is offline
Old 12-24-2008 | 03:51 PM
  #52
The shimming of the head from the factory is set for 16% nitro, so to run 30% you need to shim it at a minimum of .55mm, we shim ours at .60mm which runs really good.
Old 12-26-2008 | 04:07 PM
  #53
KWT-NITRO's Avatar
Hi Team Kamikaze,
thanks alot for the info, i shimmied mine at .61, ran it today for the first time with a nova 2630 pipe and OS P8(cold) plug, today was our first point race in the season and i got second place after a huge strugle with body/wing during the final.....the engine is great and has massive power down the straight and all around the track....my temp was around 230F.... i shaved a whole second from my best lap time by switching to the XXL3 knowing that the track condition wasen't as good as last time.....
thanks MaXPower for such a great engine, thanks team kamikaze for the info
cheers
Ali
Old 12-26-2008 | 04:28 PM
  #54
Originally Posted by KWT-NITRO
Hi Team Kamikaze,
cheers
Ali
Hi Ali,
I'm glad that I could help, the only thing I advise is, not to use an OS plug on your MAX motor, the taper is different from a Nova Rossi plug, it will leak and cause your engine to run lean.
Old 12-27-2008 | 08:52 AM
  #55
KWT-NITRO's Avatar
hello again,
i ran an oddoneil medium plug at first and the temp rised to 260, thats why i switched to the cold OS plug, what plug do you reccomend normally on a MaxPower engine??
also i noticed that the temp is very sensitive to any small high end needle tune, are all nova based engine like this?? alsxo, do you think the nova 2630 is THE pipe to use withe XXL3 or shall i switch to the Max pipe? and which one?
thanks again
Ali
Old 12-27-2008 | 09:14 AM
  #56
hello again,
thanks again
Ali
The Max pipe 2602 is the best matching pipe for your engine, and regarding the glow plug to use, I would recomend Nova Rossi 6TGF or the Ninja no.6 cold.
Old 12-27-2008 | 09:31 AM
  #57
KWT-NITRO's Avatar
thanks for the info team kamikaze, am not sure if i can find NOVa or ninja plugs here, ill have to check with our LHSs....
thanks again, and ill try the pipe next time
cheers
Ali
Old 12-29-2008 | 09:24 PM
  #58
Can someone please give me the base carb needle settings for the ax xxl3?
Thank you
mrgsr is offline
Old 12-30-2008 | 02:00 AM
  #59
stefan's Avatar
Thank you
All Nova based carbs will run with 2,5 turns LSN and 4,5 HSN
stefan is offline
Old 12-30-2008 | 02:22 AM
  #60
Thanks Stefan
im gonna try and get this engine started in the next couple of days
mrgsr is offline
