Old 01-02-2009, 06:59 PM   #61
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Thats interesting.. my XL3 and XXL3's came with 0.3mm head shim. XL3 is rad, but I have high hopes for the XXL3. Larger crank bore than the XL3, maybe after Nigel breaks in my XXL3 while I am in colorado for some "personal" business we can do some side by side testing of the XL3 vs XXL3. Two NT1's and Two maxs lol.. good times
also the XL3 and XXL3 come shimmed for up to 25% nitro. 30% add a 0.1mm shim etc. Or you can do the old offroad trick, add 0.2-0.3mm of shim to take the power down a bit and add more when it starts getting soft. obviously tune and plug will be different.
Cheers,
Patrick
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-02-2009, 07:00 PM   #62
rx7ttlm's Avatar
Originally Posted by Team Kamikaze View Post
The Max pipe 2602 is the best matching pipe for your engine, and regarding the glow plug to use, I would recomend Nova Rossi 6TGF or the Ninja no.6 cold.
Sam- order me a set of engine Orings for the XL3 and the XXL3. Tanks
Old 01-02-2009, 07:05 PM   #63
rx7ttlm's Avatar
Originally Posted by TomB View Post
lol probably. the headbutton on the sl3 is different to the new XXL3 as well. i think the XXL3 uses the standard nova headbutton instead of that funny weird button that was used in the SL3.
anyone have any advice if the head clearance is safe with the XXL3? a .1 shim as standard seems a bit low to me.
i know that headshims has to do with heat, % of nitro, sea elevation and a whole heap of other things, but any advice?
i'm thinking to stick to .3mm shims just to be safe. anyone played around with putting shims under the sleeve to changing the timing?
and if your seriously thinking of playing with crank timing by shimming start with an engine that sucks lol. IMO.
cheers,
Old 01-03-2009, 12:11 AM   #64
Cheers,
Patrick
strange, mine only came with .1mm headshims. i've shimmed it to .6mm for break-in. i'll eventually move down to .4mm
TomB is offline   Reply With Quote
Old 01-03-2009, 04:12 AM   #65
Trader Rating: 13 (93%+)
TomB run it with .1 shim
all my novas, 353 murnan, 3ct tuned and the 3t kickass are all 1mm
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-03-2009, 07:56 AM   #66
ok dude will do. Why are people saying their XXL3's came with .3mm shims though?
Old 01-03-2009, 12:17 PM   #67
Team Kamikaze's Avatar
All .12 Nova Rossi engines, including the MAX and JP comes shimmed for 16% nitro fuel, which is .3mm, it's an aluminum shim.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-03-2009, 01:05 PM   #68
G87z's Avatar
So its safe to say .4mm would be correct for 20%?
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 01-03-2009, 01:22 PM   #69
Yes, you are correct.
Old 01-03-2009, 09:54 PM   #70
yeah that's what i though. i'm pretty syre it only had .1mm. i'll double check it later, maybe the silver one got stuck to the button.
Old 01-04-2009, 04:16 PM   #71
DS Motorsport's Avatar
If you want to be sure check the squish by putting a piece of solder between the piston and headbutton, a safe squish for a nova engine is 0.5-0.6mm any lower than that and you have a high change for detonation.
I would check it first before running the engine, despite people overhere saying it's safe with .1 mm
If the engine is new, first heat the engine and then give it a full rotation with the piece of solder in place.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-04-2009, 08:24 PM   #72
ok thanks, will do.
Old 01-05-2009, 01:18 AM   #73
kickass's Avatar
Default Thomass
Thomas just run .6 This Is Really Good, also turn your shocks upside down, the car works better.
are you gonna race this year????
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 01-05-2009, 05:05 AM   #74
I just checked my max xxl3 and it came with .1mm shim only
no aluminium shim
Old 01-05-2009, 09:12 PM   #75
yeah the state titles, and a few clubbies before then obviously to get the car ready.
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
MAX POWER ENGINES Secret_weapon Onroad Nitro Engine Zone 334 08-29-2010 10:54 AM
JP Racing First Line .12 on road Stock and Tuned romuald31 Onroad Nitro Engine Zone 153 04-17-2010 05:35 PM
2nd EDITION PERLIS OPEN 09 August 2009 Aik Rccenter Malaysian R/C Racers 318 08-19-2009 09:01 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
So, with 2008 coming to an end, what changes would you like to see in 2009? quietstorm76 Nitro On-Road 52 01-05-2009 03:53 PM
