Old 01-13-2009, 05:57 PM   #91
GREGORY!'s Avatar
Originally Posted by GMartinez View Post
Mike who is that you squeezing in the pic don't look like the wife lol
g martinez do you know the timing of this engine?
anyone else?
thanks!
GREGORY! is offline   Reply With Quote
Old 01-13-2009, 09:13 PM   #92
Speyederjedi's Avatar
Originally Posted by MHarrison View Post
spey,
I tried a maxpower 2602 pipe on this motor this past weekend. And the Power was very good. Low, Mid & top end.
MHarrison,
Thanks for the info. I ran a Nova 2630 on the motor this last weekend and it was better on the bottom than with the Sirio 2611 but I think I lost a bit of top end speed. It works well at our local track though because it's so short and has a tight infield. I am going to test with the Skyline plus 12 next time out.
Regards,
speyederjedi
Speyederjedi is offline   Reply With Quote
Old 01-13-2009, 09:18 PM   #93
GMartinez's Avatar
Trader Rating: 85 (100%+)
anyone else?
thanks!
Based off the Sirio Evo 4 & tuned to capricorn specs
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-16-2009, 12:34 AM   #94
Chiefy 707's Avatar
I was thinking about replacing the conrod on my CL12E after break in. The only place I can find it is at the Capricorn site. I'm really trying to avoid ordering online from overseas vendors but if push comes to shove I just might have to.
I'm sorta sure it works but is it 100% the Evo 4 STI conrod is a perfect fit in the CL12E? Damn, so much for the cool laser etching eh?
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 01-16-2009, 04:34 PM   #95
GMartinez's Avatar
Cheif you can order Capricorn parts thru the U.S. Distributor
www.murnanmodified.com
as for the Evo4 conrods it should a direct fit but I would double check for you
Old 01-17-2009, 01:28 AM   #96
Originally Posted by Speyederjedi View Post
MHarrison,
Regards,
speyederjedi
ithink tht this pipe is the best way for your problem
CapricornRC is offline   Reply With Quote
Old 01-17-2009, 10:26 PM   #97
Chiefy 707's Avatar
I just didn't see any listings for a conrod on the Murnan site. But still, thanks for any and all help.
Old 01-18-2009, 05:21 AM   #98
Grinder's Avatar
It is there now.
Check under engine parts.
Grinder is offline   Reply With Quote
Old 01-18-2009, 06:28 AM   #99
KyoshokiddT.D's Avatar
is this pipe legal to use in a national or world event ? big tom
KyoshokiddT.D is offline   Reply With Quote
Old 01-18-2009, 05:20 PM   #100
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Ran the 12ET MM motor for the first time over the weekend. It behaved flawlessly, made good power (but was hard to compare to my other engines as it was a very small and low traction track). I ran it with the 2611 pipe, but have a 2604 pipe that I plan to test at a larger track.
It has about 2.3 litres of Tornado 16% fuel, it was still locking up on the starter box before the mains, I still cannot turn it over without a plug, so this is very impressive!
I pulled it apart last night, the internals are all still shiney and look brand new, it didn't see past 118deg C. The piston/linear is bedding in very nicely. This motor has alot of potential, I still think it is about another 1-2 litres away from its full potential. I will order a spare rod for it, as I think this tight pinch could be adding some extra strain on it.
I agree with most of the above comments, yes it is a Sirio based motor, but I think the quality is much better. I ran the new Sirio XXX about 1 month earlier and it did not have anywhere near the amount of pinch the Capricorn has.
But so far, two thumbs up
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 01-18-2009, 05:30 PM   #101
GMartinez's Avatar
Tom is has a new efra #2648
since there was a change to the original 2611 under efra rules & was not sudmitted to efra on the changes that's why it was ruled illegal & then had to be resubmitted with the changes in order to receive the new efra #
Old 01-19-2009, 02:05 AM   #102
Chiefy 707's Avatar
Originally Posted by Grinder View Post
It is there now.
Just did and just ordered! Thanks!
Old 01-19-2009, 07:47 PM   #103
GMartinez's Avatar
anytime
Old 01-20-2009, 05:25 PM   #104
Michael_T's Avatar
The guys that found the 2630 to be the better pipe, what manifolds did you find to have the sweet spot, 5/6/7 fin?
Old 01-20-2009, 06:22 PM   #105
MHarrison's Avatar
5 Fin
MHarrison is offline   Reply With Quote
Capricorn .21 CL-9TE competition engine CapricornRC Onroad Nitro Engine Zone 31 07-20-2012 12:28 AM
Capricorn Q12ET hobbypro Nitro On-Road 6 06-16-2009 07:55 PM
CapricornRC - Present and Active CapricornRC Nitro On-Road 15 06-16-2009 05:51 AM
