Capricorn CL-12E engine
I have to admit that is quite a bit different than I was expecting from Capricorn, I would have expected something more similar to Picco/IDM but the 3 needle carb with the inserts is cool. The 2617 pipe is the pipe Daniele won the worlds with (or at least that efra #)
The engine packaging is very cheap, very domestic...... when I received the engine, the enigne was in a sandwiches bag. (This engine is the tuned version...... stock version only came with silver engine case and no modification) The modification is pretty humdrum...... no surprise. Lucky I knew engine modification......... this enigne must be re-worked.
Will pass on the info on the packaging advice.
Overall on the motor the tuned version is very fast ran it this weekend @ the Sedan Nationals flawless performance thru out the event just wished my driving was as good as the motor
I ran Sirio for more than 3 years & now running for capricorn Im happy with the performance from the CL.12E with the 2617 pipe & will give you some updates when I test it with the 2611 & also keep everyone informed on new products
Blee just got back a reply from the owner what you have there is the pre production exactly what I received as well. The final packaging should be available in 2 weeks. just my 2 cents take the non modified version & do your own mods to it that way you can compare the performance between the 2.
Thank you for info......... however I didn't complain the packaging but I told the truth.
Also I don't mind the performance of tuned version or stock version, I will modifiy to my own standard anyhow. For my experince, I could modify the tuned version to a higher level definitely. I belive this tuned version will need less modification job also.
Following are some preview of Capricorn Engines and muffler kit boxes.
We apologize with the costumare that were not sotisfied from the oem packaging and leak of documentation.
Was the very early batch of engines sent to Uriah in order to use them at Sedan Nat.
We will do our best to fully sotisfy all our costumares.
Always ready to give info and support at [email protected]
Best Regards
Capricorn RC
Best Regards
Capricorn RC
Best Regards
Capricorn RC
Best Regards
Capricorn RC
I see.... you should send me a new box, engine manual and stickers.
