Old 08-06-2007, 07:08 PM   #91
What is offical IDM url?
ioxqq is offline   Reply With Quote
Old 08-07-2007, 05:00 AM   #92
As bad as it seems Daniele is still working on the site. I will have our site up in I think 5 more days with all the support for the engine line here in the U.S. Just has taken longer then expected. Check www.teamxspower.com in a few days we should have switched the site by then.
xspower is offline   Reply With Quote
Old 08-08-2007, 09:25 AM   #93
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The .12 engine is good. I ran it at the Great Lakes Challenge. The most launch I have ever experienced. I had to change my entire clutch to make it work. Very good top speed and great fuel economy.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-08-2007, 10:44 AM   #94
Can you share your clutch, gearing and track surface? I've had this engine for a few weeks now and my home track is permanently unusable so I would like to have at least a decent starting point before a large race coming up on the very first weekend it's available.
brianhatesnitro is offline   Reply With Quote
Old 08-08-2007, 12:31 PM   #95
I ran the Kyosho 3d clutch with the stock weights and the grey shoe. I used the Kyosho FMW16 spring compressed about .9mm below the crank end. I ran the tallest pinions 17/23 with the 55/60 spurs. The track had very good grip.
Old 08-08-2007, 02:50 PM   #96
Motorman's Avatar
Thats what I ran. Only diff was I used a Orion square wire spring.
I have to agree Scott. I was duly impressed with the out of the box haul azz these have. There as fast as any of my best hand modified motors.
Unfortunatly my radio was not nearly as cooperative as my engine was over the weekend.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-16-2007, 09:58 PM   #97
Team Kamikaze's Avatar
Dennis,
Good to see you come back to the RC racing scene.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-18-2007, 07:35 PM   #98
have any of you had luck with the 2617 pipe? I tried it today and my track seems too tight and the engine kept getting too low in the rpm to be useful.
Old 08-18-2007, 09:07 PM   #99
I have not tried the 2617 pipe. Only the 2607.
Old 08-19-2007, 06:13 AM   #100
The power band on the 2617 pipe is real short and comes on fast. It is a real short pipe. if your track is to small it may not be the pipe of choice for that application. Remember that the shorter the pipe the "more top end" you will get to faster and the less lower end you will have. The longer the smoother the power band and the longer the transition from the low to mid to high. A nice long "linear' curve you will have.
Old 08-20-2007, 08:12 AM   #101
That was exactly my experience with it, but my track is fairly tight with enough low speed corners that it fell out of the powerband in 3-4 corners so I went back to the 2607 to put the tq down by 8 seconds at the southwest series race but a dogbone took me out at the 20 minute mark with a 16 second lead on 2nd place.
The IDM evo3 performed extremely well this weekend, it was more than a match for SL3's and 353's except for the first 5 minutes in the main. Some how these drivers were gaining 5 feet on me in the straight until after the first pit stop and then I was back to pulling them, guess they started off a bit too lean to run for 30 minutes.
Old 08-20-2007, 09:25 AM   #102
YBSLOW's Avatar
Default clutch setup for IDM
Just wanted to give a basline clutch setup for the IDM .12 in a MTX4:
flyweights drilled out to 4mm
MSR clutch spring
yellow clutch shoe
clutch nut 0.9mm from end of crank shaft
0.3mm gap
I have only tested the 2607 pipe so far.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-26-2007, 08:42 PM   #103
Trader Rating: 15 (100%+)
I ran my .21 IDM on-road motor again this past weekend. It continues to perform great and have a consistent tune. Several racers (and even a couple spectators) commented about it's performance as well. Don't be afraid to give the IDM's a try !!
jpeck is offline   Reply With Quote
Old 08-27-2007, 05:11 AM   #104
That is good to hear that the engine is running well John!!!
Old 08-27-2007, 02:05 PM   #105
rmdhawaii's Avatar
Brian ~ Just curious: What size tires did you start off with and what size were they after 30 minutes?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
