Old 09-05-2007, 05:51 AM   #121
Are any of you running 20% fuel? I changed the deck height on the Evo3 down to 0.44mm, ran 20% with the 7 plug and got about 6.5 minutes of runtime and crazy power.
brianhatesnitro is offline   Reply With Quote
Old 09-05-2007, 06:32 AM   #122
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i run 16% , removed one shim, use the 2607 pipe and make 6 mins also. and very good power. i run the bottom end pretty rich, and top a bit lean, the engine loves it. te4mps are around the 260F dependant on the days weather.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-05-2007, 08:01 AM   #123
You should not need to remove a head shim from the engine it comes set for 16% from the factory. That is unless you are 1500 feet or more above sea level. You will find if you keep the head a bit high you will gain some top end out of the motor. "as if it needs it" and it will soften the punch a bit. The needles are set right that is the way the IDM and for that matter all the Picco based engines like to run. Using 20% will allow the engine to live a bit longer and you will get better fuel milage with no questions. The number 7 is also a good idea if it is hot or humid outside.
xspower is offline   Reply With Quote
Old 09-05-2007, 08:16 AM   #124
My crude crushed solder method of measuring deck height may be a bit off, but I believe mine was shipped with a clearance of 0.65mm and I was originally running 30%. I'll have to try the 0.65mm setting again (2 thin, 1 thick copper shim) with the 20% and try again next time my track is dry but this seems to be doing well already.
Texas has some wicked humidity, over 80% most race days..
Old 09-05-2007, 12:17 PM   #125
Yeah but that method is not that bad. We just like to see it in Inch not mm. For some reason makes it easier to remember I do not know why so do not ask!! LOL
Old 09-08-2007, 10:45 PM   #126
kcrunchone's Avatar
Hey Jerry
Received my package thanks again and glad to be on the team. If my engine runs half as good as Dennis did in GLC I should be just fine. I have to start break in in the morning since I am just getting off from work so late. Hope to see you soon.
Dennis will you be at 301 ??
If so see you there...
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 09-09-2007, 03:25 AM   #127
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by kcrunchone View Post
Hey Jerry
The fast girl in our team is Daniele's girl fiend and she ran his engines at the German nationals last week for the first time. Serious punch!!
Although I'm sure her engines have been prepared with love
Soon, we will have the distribution for those in the team as well. Looking forward to it.
stefan is offline   Reply With Quote
Old 09-09-2007, 03:37 PM   #128
You will be happy with the engines I am sure. They are really fast as well as reliable. Good luck with the engine line!!
Old 09-10-2007, 11:01 AM   #129
YBSLOW's Avatar
Default Nats
Thanks XSPower/Jerry for the awesome motors at the Nats. Motors ran flawlessly for all six qualifiers and were as fast as anything there. All six qualifiers were good enough to put me directly into the semi-finals and in a bump position until a mishap in traffic.............................next time.
Brad
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 09-10-2007, 11:09 AM   #130
YBSLOW's Avatar
Default PIcs
Here is a pic of me marshalling and the other pick of my MRX-X with a Black chassis.
YBSLOW Racing
Old 09-13-2007, 09:05 PM   #131
kcrunchone's Avatar
All I can say is WOW ! ! ! I received my package thanks to Jerry TEAMXSPOWER IDM ENGINES and broke it in put it on the track and if that is the power I have on command I LOVE IT...
I am sure this is the start of something GOOD ! ! !
Rick Hill
Old 09-14-2007, 12:28 PM   #132
Well that is good to hear. Thanks for the time and sorry for the mishap with the shipping!!!!
Old 09-20-2007, 03:44 PM   #133
1FastSerpent's Avatar
Got the package today, thanks for the fast service Jerry.
1FastSerpent is offline   Reply With Quote
Old 09-20-2007, 07:24 PM   #134
Thank you for the support with the line and the other help you have given!!!!
Old 09-23-2007, 07:06 PM   #135
What do you guys feel about fuel tubing lengths on the inlet and on the exhaust pressure side?
CEN Products SCOOTER29 Rookie Zone 9 09-22-2005 01:57 AM
cen products chifan26 Nitro On-Road 7 09-19-2005 02:50 PM
