IDM Products?
#512
Btw, I have a problem with my 2607 pipe.... We had talked about it in this forum, it had a piece of gasket in it, I could see it on one of the chambers,and I tried to blow it off with a compressor, and thought it went away as I no longer saw it.
Recently I tried it, my motor revved nice at first, and I put it on the track, drove 1 lap, and bogging sound came again, and it stalled. I tried to fire it up several times, and it was stalling immediately just like the motor was way too rich... I changed the pipe and problem went away.
So, anyone knows how can I solve this problem?
#514
Suspended
This carburator will not leak or deviate during driving.
#515
I put the race tune on this engine this past weekend, I must say I am impressed with this engine. I ran the 2033 pipe, will try a 2052 next race. Also impressing is the engine quality, I disassembled and checked the whole engine for wear. Conrod, crank and pin. You couldn't tell this motor had been run.
#516
Glad to her that you liked the engine. The engine really has done well for itself. Also you may want to try to use the new 3031 pipeset as well. We tested with it and were pleased wth the results. Alot of people are running the 2013 and they have said they also work well. We used the 2052 on the old series engines as well as the Mega line so we would get more top speed. Let us know how that works. I would use a medium length header with that pipe to start.
#517
Daniele told me that the metal insert in the carb is now steel not alu anymore.
#520
Suspended
This is new for me, never had this problem.
#521
I have seen many sedans stripping gears now Kyosho, Mugen, you name it the .12 engines have alot of power for a small package. And I think that the chassis's are flexing some and causing the pinions and spurs to move farther from each other resulting in larger gaps. Then when the car hits second well there is goes. The teeth that is. Just what I have heard and seen. Think about the this as on a 1/8 scale the actual thickness of a spur gear is almost double the thickness of the 1/10 and the engines are only under 1 hp less. only 1/3.
#522
from this statements around here it proves existing idm evo3 is up to date engine on power wise, consumption and durability. i have no doubt the idm evo4 would be better
definitely my next motor if my budget permits me.
#523
Well you should not have much of a issue the pricing on the engines are very good for the hand work to the engine that you get on the piston liner as well as the crank shaft timing. As well as the assembly by Daniele. I cannot speak enough to say that all the Picco based engines have shined through alot more in the recent times and have defiantly proven themselves.
