Like Tree1Likes
JL Racing .12
Old 06-23-2008, 02:07 AM
  #1576
Originally Posted by gentleman81
i will look tomorrow and let u know what i have. but i am running the yellow shoe and MSR spring, so it wont be the same.
u should be able to start at the mugen specs that are in the manual
What difference do you see when using the yellow shoe and MSR spring from stock setup?
sllo is offline
Old 06-23-2008, 11:13 AM
  #1577
gentleman81's Avatar
it engauges harder which will allow u to have harder acceleration. but it depends on the track conditions too. for lower traction you dont want the clutch to come one to hard. it will break traction. but it can be adjusted
gentleman81 is offline
Old 06-23-2008, 04:22 PM
  #1578
Default Thanks
Thanks Sam at Kamikaze for the Red Dot parts and everything else I needed!!!
I think they have a private jet for super fast shipping!!!
Old 06-24-2008, 09:08 PM
  #1579
cracked my red dot open today for the first time. it runs great but time for some maint.
i notice that i have a burnt brownish residue inside the button head and the head of the piston has this also. along with what may be the begining of pitting. it doesnt seem to be in the metal, just ontop where it should be brown there are some specs of clean metal.
the rod is going in tomorrow, i have heard of something that can be done to brighten the piston head back up, does anyone know?
Old 06-25-2008, 01:54 PM
  #1580
roadrage's Avatar
Trader Rating: 14 (100%+)
you want to see brown on top of the piston,this is showing that the motor is burning oil which is a good thing. as far as the pitting goes that shows that you have detinated a plug and may decrease the performance of the motor.try adding a .1 head shim shim
roadrage is offline
Old 06-25-2008, 09:01 PM
  #1581
thanks man, did u go the the cap classic?
Old 06-26-2008, 07:00 AM
  #1582
roadrage's Avatar
no i missed out but ill be at the winternats in ft. myers
roadrage is offline
Old 06-26-2008, 06:19 PM
  #1583
TeamCarnage's Avatar
Trader Rating: 31 (100%+)
Sam- Recieved the Evo3 today! Thanks for the great service! I took it apart and it was spotless. It fired right up, and idled great. I'll finish break-in and have it ready for this weekend for the Byrons Race at Leisure Hours Hobbies this weekend.
For the record, my 1st JL lasted through appx 7-7.5 gals. from last season till now. I raced an MWS event in Cleveland last weekend, and it started to run hot. It never let up and it tempted at 300* after a .5 hr. main. I ordered a new mill Sun. night. In the meantime, I tore down the original mill and found all was well,, The main bearing is a little gritty, but the P/S fit was way better than I expected!!! I only hope to get the same service outta the JL3!
GoodRacing! Nick
TeamCarnage is offline
Old 06-26-2008, 07:03 PM
  #1584
Team Kamikaze's Avatar
GoodRacing! Nick
Thanks for the good words, anyway the new EVO 3 engine should last you the same way your old mill does, but I suggest you replace the con-rod on your JL that just run at 300 F degrees, to further prolong the life of that engine.
Team Kamikaze is offline
Old 06-29-2008, 07:17 PM
  #1585
badKarma's Avatar
hey guys,
quick question...just finished the chassis portion of the NT1 and cracked the box open on my JL...whats the best plan of action? do i need to disassemble, oil down the internal parts, and use silicone sealer around the carb neck? how should I approach this?
badKarma is offline
Old 06-30-2008, 05:36 AM
  #1586
keavze's Avatar
Default IDM and JLR conrod
is the conrod for the JLR and IDM interchangable?
keavze is offline
Old 06-30-2008, 10:05 AM
  #1587
roadrage's Avatar
yes
roadrage is offline
Old 06-30-2008, 10:06 AM
  #1588
roadrage's Avatar
Originally Posted by badKarma
hey guys,
disassemble to make sure theres no burrs of metal and just grease the neck of the carb for a smooth entry.
roadrage is offline
Old 07-01-2008, 09:55 PM
  #1589
badKarma's Avatar
guys, what happens if you run the JL .12 in the NT1 but using the flywheel collar that comes with the engine instead of the 6mm Xray collar? can anyone advise? thanks
badKarma is offline
Old 07-01-2008, 09:57 PM
  #1590
Nothing will happen.
