OS R2106
#31
I have been reported with one incident until now, a very light seisure due to cold weather circumstances and maybe engine being a little too cool.
#37
#38
Made it for you : https://www.worldchampionproducts.co...r21062165.html
#39
I have received an 2106, thanks Rody for the fast service!
Timing wise it must be a faster engine than all previous models, the crank has 5 degrees more opening and the transfer ports are 1 degree higher compared with the 2105. Also on the side where the opening was extended I predict the engine should give a faster response on the throttle
Funny thing is that the exact same crank timing is used with the 5 port "sports" R21-v2 I also got. The v1 version has 10 degree less opening..... It will be THE choice for the ENS stock class.
#40
Hi Roelof,
Thanks for the feedback.
Basically the R2106 and the R21-V2 are the same engines, except for that there is a difference in qty of inlet ports, no DLC on the crankshaft and black anodised crankcase and a less lighter coolinghead.
For me the R21-V2 is a very good engine to start with.
#41
Hi Roelof,
It is not only the amount of ports but more the transfer port timing. Both the R21 models have about the same port timings that is much lower than the 210x models, a simple sleeve shim can improve that.
Nice that you mentioned the cooling heads. I had some in reach and a new small weight scale so I could weight some:
- R21-v1: 64gr
- R21-v2 60gr
- R2106 51.4gr
- R2105 50gr
- Hasi upwards fin 49gr
- My head 63gr
And while I was busy, a standard OS P/S set weights 26gr and an Hasi AAC p/s set 11.5gr.
If the EFRA will lower the minimum weight to 2250gr or a middle way with 2300gr I foresee more weight loss on the engines like Ielasi already does with removing the upper fin and DB does mill away a lot from the crankcase.
#43
Well..... it is a known thing that the top fins are taking a small part of the cooling but with the high position of the body there is hardly a fin sticking out with a cut off head and then I think a full size head sticking out more above the body will provide a better cooling. But hey, Ielasi does now sell a thick plate of aluminium with which you can raise the head.
#44
Plan to run the ENS next season? (considering seriously...) Finished break-in the R21-V2 and taking my time on the Euro Spec II (liking a lot of it with the 2115 pipe).
Thursday surrendered and got into (additional) problems ordering a 2106 with other bits from Chez Rody (ETA: Wed). Thinking seriously to look for an oil break-in for it (forgot to add the EBIS option while I was ordering...
P.S: Still not sure if the 1F400 model (Ver 2) will be accepted on the ENS next year. But gambled about it just in the case...
If not. Is a nice practice one for winter time with low low traction on my track.
).P.S: Still not sure if the 1F400 model (Ver 2) will be accepted on the ENS next year. But gambled about it just in the case...
If not. Is a nice practice one for winter time with low low traction on my track.Last edited by SEF450; 11-30-2025 at 09:33 PM.
16Likes
