Like Tree92Likes
OS R2104 engine Thread
Old 04-27-2021 | 09:15 AM
  #136
VS_Rody's Avatar
R/C Tech Elite Member
Originally Posted by madjack
Does anyone have experience with replacing the stock OS OEM bearings with ceramic bearings?
Was there a noticeable difference in the motor spooling up?
For me there is no real noticeable difference between steel or ceramic.
Also very hard to understand when a ceramic bearing goes bad.
Overall it is cheaper to refresh a set of steel bearings compared to ceramics which really hurt your wallet.
VS_Rody is offline
Old 05-04-2021 | 07:00 AM
  #137
BigC2007's Avatar
Hey guys I seen in another post that a lot of the 2104 are having issues with piston scratching during break-in. Any advice on breaking one in to avoid this ?
BigC2007 is offline
Old 05-04-2021 | 08:41 AM
  #138
Roelof's Avatar
Use a fuel with more oil (RTR fuel or add some extra castor) and be patient, take all the time and at least 2 liter of fuel.
Rick Vessell, madjack and VS_Rody like this.
Roelof is offline
Old 05-04-2021 | 09:39 AM
  #139
I use an engine heater also during the break-in process.
Rick Vessell likes this.
madjack is offline
Old 05-04-2021 | 09:52 AM
  #140
BigC2007's Avatar
BigC2007 is offline
Old 05-04-2021 | 12:13 PM
  #141
VS_Rody's Avatar
During-breaking, avoid high rpms.
Make your clutch come in very early and also make the shifting into second-gear early too.
Try to put load on the engine with early rpm, not the high screaming things.
Also put some extra oil, this will never hurt.
VS_Rody is offline
Old 05-04-2021 | 12:15 PM
  #142
I just broke one in 2 weeks ago, didnt have any problems. Ranned on in the oil bath, then one bottle rich, let cool down, one bottle leaning it a bit each tank, then one bottle making power but on the rich side. I did add oil to the fuel
nitrodude is offline
Old 05-04-2021 | 12:45 PM
  #143
BigC2007's Avatar
Thanks Rody
VS_Rody likes this.
BigC2007 is offline
Old 05-04-2021 | 12:46 PM
  #144
BigC2007's Avatar
Sounds good thanks Steve
BigC2007 is offline
Old 05-17-2021 | 05:40 PM
  #145
3DFLYER's Avatar
Default Exhaust updates
Hey guys,
I ran the MR03 and TR01 2165 pipe all weekend at the latest state titles with great results. Engine was fast and bulk acceleration out of the corners.
VS_Rody likes this.
3DFLYER is offline
Old 05-24-2021 | 08:20 PM
  #146
blanks596's Avatar
Wink
Originally Posted by 3DFLYER
Hey guys,
how did you keep it from melting the body?
blanks596 is offline
Old 05-26-2021 | 03:50 PM
  #147
3DFLYER's Avatar
Using the Xtreme stiffners on diablos but where the header sits in using just a protoform 90° type stiffner to allow it to clear the header.
Could also use the carbon brilliant RC ones also
3DFLYER is offline
Old 05-27-2021 | 01:00 AM
  #148
3DFLYER's Avatar
Here's a couple pics mate
3DFLYER is offline
Old 05-27-2021 | 07:44 AM
  #149
Max, do you think the pipe will hit the body with the MR03? I haven't had this problem.
Old 05-27-2021 | 03:36 PM
  #150
3DFLYER's Avatar
I found the MR03 hits the stiffners on my Shepherd using precut diablo and super diablo.
3DFLYER is offline
