Ninja Engine by GRP
Old 09-03-2007 | 04:26 AM
  #1186
rcfoolz's Avatar
Originally Posted by gentleman81
so what is looking like the life span of these ninjas? 12s?
i know a guy that has had half a season on his and it is about done?
I've ran mine since they first came out. Here in FL, we race at least 3 or 4 weekends out of the month, so I would say that mine has at least 4 gallons ran through it. It is a fast motor .... ran past a Murnan 12+3 out of the corner...down the straights, and runs a temp of 220 (on an exergen) and getting 5 1/2 min on a track that is known as a motor killer.(your on throttle almost the whole time)
rcfoolz is offline
Old 09-04-2007 | 12:07 AM
  #1187
FF25510's Avatar
after over 20L on my ninja, all looks fine but ahhhhhhhh
i have had two very hard crash on the manifold and damage the crankcase. but you can see a small hole inside.
Attached Thumbnails Ninja Engine by GRP-ssl10173.jpg   Ninja Engine by GRP-ssl10182.jpg   Ninja Engine by GRP-ssl10175.jpg   Ninja Engine by GRP-ssl10180.jpg   Ninja Engine by GRP-ssl10185.jpg
FF25510 is offline
Old 09-04-2007 | 01:13 PM
  #1188
wallyedmonds's Avatar
man thats bad luck.
i just do this to my fls pipes
wallyedmonds is offline
Old 09-08-2007 | 10:36 PM
  #1189
kcrunchone's Avatar
Originally Posted by wallyedmonds
man thats bad luck.
Well I guess that is a flaw I ahve had the asme on both the FLS pipe and muy regular pipe and the same with tmy crank case as well while at the GLC....
http://home-and-garden.webshots.com/...17417077gLvoMQ
kcrunchone is offline
Old 09-08-2007 | 10:56 PM
  #1190
FF25510's Avatar
Oh, then i was thinking about the quality problem, i never had this breakage problem with the other brands (i only used NOVA, MAX, RB) even crashes the manifold to bend. Other then that, the NINJA had the most power and speed (to me)
FF25510 is offline
Old 09-09-2007 | 02:28 AM
  #1191
stefan's Avatar
Could it be that the stiff connection of the FLS is transmitting vibrations throughout the engine/exhaust, which have been dampened by the spring connection of the old one-piece pipes?
stefan is offline
Old 09-09-2007 | 03:05 AM
  #1192
FF25510's Avatar
No, i'm using the Mugen 2501 pipe, (also show above) maybe the manifold was too stiff , the manifold not even bend but crankcase was break.
FF25510 is offline
Old 09-09-2007 | 11:14 AM
  #1193
Maximo's Avatar
Originally Posted by cdelong
the taper at the conical end of the plug is most likely different- possibly the threads as well. It's best to stick with the Ninja plugs on the Ninja.
I know an OS turbo plug will not thread into a Nova head button- same concept.... it just doesn't jive.
Boss and Falcon plugs are identical to the Mugen plugs...The Boss engines are a mirror brand of the Ninja motors, the Boss products even come on fancy plastic cases just like the Ninja products....... Boss=Ninja and Ninja=Boss
Maximo is offline
Old 09-19-2007 | 04:44 PM
  #1194
gentleman81's Avatar
best ceramics to get for next year?
gentleman81 is offline
Old 09-19-2007 | 04:50 PM
  #1195
Wolverini's Avatar
Acer
Wolverini is offline
Old 09-19-2007 | 06:33 PM
  #1196
where are the boss products found?
Old 09-19-2007 | 08:16 PM
  #1197
BlackedOutREVO's Avatar
R/C Tech Elite Member
What nitro is everyone running?
And what %?
Are the ninja's easy to tune, and do they hold a tune well?
I know I will have to tweak it and all, but in general?
What need to be done to the engine out of the box? I knw carb sealer, anything else?
BlackedOutREVO is offline
Old 09-19-2007 | 08:32 PM
  #1198
And what %?
tornado 16 or 20% never again will i run 30% but maybe 25%
in general i always take a new motor apart and clean it,the sleeve i use a round rubber bit on a dremal and clean the ports carefully oil and put it back together and never take it apart again.
and ya seal the carb this is a must.
break in look for mike's post on this thread way back.
Old 09-19-2007 | 09:01 PM
  #1199
I wont take it apart lol... That scares me
I dont want to mess it up, once I work with them more I will.... But not now, atleast not me doing the operation......
20%, the hot fuel at my track is Werks, anyone use that? And I will run 20% also, 30% runs awsome, but the wear on the engines isnt worth it....
It will be fun getting back into nitro
Old 09-27-2007 | 04:16 PM
  #1200
Lance72RC's Avatar
what's the differences between the MR21-R01 and the R01A?????
Lance72RC is offline
