Ninja Engine by GRP
Old 02-27-2007 | 12:21 PM
  #466
cdelong's Avatar
I use Cyrul's WOT method. I mill a spare head down so it has only two or three fins remaining to keep temps up.
Up north in the winter you may need a heatgun, but down south or in the summer the milled head is enough to keep temps up to 180- 200F at WOT.
cdelong is offline
Old 02-27-2007 | 12:33 PM
  #467
Racing4Evo's Avatar
It's a good idea to mill an extra head but the problem is getting that extra head. Most people don't have an extra head for a new engine especially one as new as the Ninja.
Racing4Evo is offline
  #468
Pooh2's Avatar
I'd do what Swauger says. He had the FASTEST engine at ft myers!!!!!!! And ALWAYS has power!
Pooh2 is offline
Old 02-27-2007 | 03:16 PM
  #469
afm's Avatar
afm
Originally Posted by Mike_Swauger
1st Tank at idle. Shut it off and let it cool down. Make sure the piston is at the bottom.
2nd tank idle
3rd tank 1/4 throttle
4th tank 1/4 throttle
5th tank 1/2 throttle
6th tank 1/2 throttle
7th tank 1/2 throttle
8th tank full throttle (make sure engine is running rich)
9th tank 1/2 throttle
10th tank 1/4 throttle
Put the engine in the car and run two or three tanks at a rich setting on the track and then it will be o.k to lean it out.
Mike
Thanks for the precise method
AFM
afm is offline
Old 02-27-2007 | 04:02 PM
  #470
nitro_moe's Avatar
2nd tank idle
Thanks for the pricelss tips Mike.. Sharing such tricks of the trade are a unique quality of a true professional. Hats off to you Mike..
One last question though if you don't mind. Do you mean blipping or holding it steady at 1/4, 1/2, and full throttle during the tanks you mentioned..??
nitro_moe is offline
Old 02-27-2007 | 04:06 PM
  #471
Originally Posted by nitro_moe
Thanks for the pricelss tips Mike.. Sharing such tricks of the trade are a unique quality in a true professional. Hats off to you Mike..
You want to keep each tank steady. One thing I forgot to point out was do not let the tank run out of fuel while break-in. It could lean out and cause damage to the engine.
Mike_Swauger is offline
Old 02-27-2007 | 04:13 PM
  #472
nitro_moe's Avatar
Will do for sure.. Thanks again Mike
Old 02-27-2007 | 04:43 PM
  #473
HarKonnenD's Avatar
Mike - would you recommend this method with other engines or specifically the Ninja? Just wondering.
HarKonnenD is offline
Old 02-27-2007 | 04:48 PM
  #474
I have used this method on Ninja and Nova engines. I never tried it out on any other brand engine.
Old 02-27-2007 | 08:02 PM
  #475
Roger's Avatar
Originally Posted by jfro6512
Which stores have em' already???
Jerome: I should have them friday for ya.
Roger is offline
Old 02-27-2007 | 08:35 PM
  #476
PROVK's Avatar
Is there any problem using Novarossi plugs in the MR21 R01A and if its ok
would you use C7TGF/C8TGF as I am new to 1/8 scale on road.
I will be using 25% nitro
Thank you
PROVK is offline
Old 02-27-2007 | 11:44 PM
  #477
moy's Avatar
moy
hey mike.. when is the new MR21 gonna go out of the market?along with the new pipe? (magnesium).
moy is offline
Old 02-28-2007 | 12:27 AM
  #478
M7H's Avatar
M7H
We have been breaking in both the .21 and .12 on the prop. I would stay away from the WOT method if you can.
Haha, where RickV recommends the WOT for the Ninja engine.....
And every race a new one......
Come on people, there are a few good break-in procedures, and all of them have the same result.....
M7H is offline
Old 02-28-2007 | 02:04 AM
  #479
gashuffer's Avatar
Moy, They will be here April-May, I asked that question a few posts back.
gashuffer is offline
Old 02-28-2007 | 03:56 AM
  #480
SalvadoriRacing's Avatar
Whats up Lil Paul!
When you use the Hudy bench don't worry anout getting your engine up to the same temp as you would on the starter box. When I use the break end stand the temp will be under 200F. I run 10 tanks through the stand and two rich tanks on the track then it is o.k to lean it out.
10 tanks on the bench with a propeller = about 3 hours of breaking in!?!?!?!??!??!
I may be wrong, but I use to run 4 tanks at full throttle on the breaking in bench and it lasts about 45min.
SalvadoriRacing is offline
