Ninja Engine by GRP
#334
I just got a b01a today, anyone know the difference from a b01? its suspose to be the latest version but i dont know, also i want to run 30% should i use both shims that came extra with the motor? thanks paul
#340
If your referring to No.1 engine MugenDrew. Your assumpation is correct. Yes the TCS ring is cracked. I've had guys with decades of experience have a look at it and the bottom line is it leaks around the block near where the burn room goes. So be it then. I'm not that worried about it.
No. 2 engine so far it's as good and reliable as any Nova I've had.
