Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Thunder Innovations Nitro Pre Heater Problems >
Old 08-15-2012 | 04:43 PM
Todd Racing's Avatar
Default Thunder Innovations Nitro Pre Heater Problems
thread removed
Todd Racing is offline
Old 08-15-2012 | 05:33 PM
bigjayjay1's Avatar
What are you using as a power source the comp heater is a excellant safe product but if you jacking up the volts you will have issues. 12 volts Max
bigjayjay1 is offline
Old 08-15-2012 | 05:36 PM
thread removed
Old 08-15-2012 | 06:09 PM
hookem34's Avatar
R/C Tech Elite Member
Confucius say " when you buy cheap Chinese knockoff to save some cash, you will always take it in the ass".
Make your next heater a Comp Heat and never look back.....
hookem34 is offline
Old 08-15-2012 | 07:19 PM
rider313's Avatar
A bit of a harsh way to put it but I have to fully agree.
rider313 is offline
Old 08-15-2012 | 07:20 PM
houston's Avatar
I think i'd rAther get the real thing
houston is offline
Old 08-15-2012 | 08:14 PM
Stubbs's Avatar
And this is the prime reason why I'm glad I bought a genuine Competition Heat......two actually. My first one is close to three years old, and doesn't have a stitch out of place. Only reason I sold it to my buddy is because I got a deal on the new Deutsch connector version.
I understand the allure of lower price, but I had a good feeling that the "Thunder Imitation" was going to have quality issues.
Stubbs is offline
Old 08-16-2012 | 09:11 PM
RMKinWI's Avatar
I have two of the Thunder heaters and both have burned through the fabric in 6 Months of use. If i'd only known - I would not have thrown out my previous 3 comp heaters after the heat element stopped working. I could have used the old comp heaters case with the thunder heater element.
Regardless of which product I buy I can only get 6 months out of them. Running two classes and using the heaters for longer than there intended to be and connected to my 13.8 volt power supply.
After owning both they look the same but are different. The thunder is cheaper in cost and quality.
The worst was when my pit guy pulled on the wire to remove the heater and pulled the wire right out of the element on my brand new first time out thunder heater.
Your not having fun unless your spending money
RMKinWI is offline
Old 08-16-2012 | 11:41 PM
Roelof's Avatar
Did forget to power off when removed from the engine?
Roelof is offline
Old 08-17-2012 | 05:22 AM
VPProUSA's Avatar
Originally Posted by Todd Racing
Has anybody had any problems with this unit like me, mine has smoked since day one and caught on fire twice now, velco strap totally has burned off, needless to say its junk now LOL, back to heat gun till I get a new one that is if theres track power available, check these pics out and only been used at 3 races
Did you contact Thunder Innovation yet? [email protected]
They have good customer service and will warranty any manufacture defects.
I have been lucky, mine is 8 months old and still looks new. I have only seen a few burn through like yours. To prevent this, TI said not to use over 12.6v. Do not use an automotive battery because they are over 12.6v fully charged and make sure if you use a power supply, it is not putting out more then 12.6v because many actually put out over 13v. I use a 3 cell lipo to power mine.
VPProUSA is offline
Old 08-17-2012 | 01:52 PM
Exactly right! i guess its easy to blame the product first though.
I have been using mine for several months now with zero issues, i am using 3 cell lipo as power source. It clearly states in the instructions not to use above 12.6v which automotive batteries will be.
I know a guy who paid a premium for the comp heat version and it only lasted 3 or 4 months before the wires broke at the element. Product fault or operator error??
ArgusNZ is offline
Old 08-17-2012 | 03:33 PM
bigjayjay1's Avatar
Thats what I bought a power supply with adjustable voltage a typcally power supply uses over 13V NOT good. Before moving into a Comp heater I used the Thunder heaterit burned really bad and tossed on the ground then my son kicked it and by luck it went into a storm drain called for a replacment > they said i was crazy
Comp and their products are BETTER with GREAT service.
Old 08-17-2012 | 03:41 PM
Old 08-19-2012 | 06:32 AM
Update, Just heard back from Thunder Innovations and all is good, He is going to replace unit, he is sending out next week, hopfully new one will not have same problem Cheers Phil
