Go Engine USA 2011 Thread
#1441
I get my HO on Saturday,which just so happens to be my birthday
...iim getting production # us00000004. Or however many zeros lol.....thanks jason (shotime) . Gotta love how much of a family we all are with thes Go Engines
#1442
#1443
WTS... i thought they where all sold out in usa??? i have number.....000000000000000000000000000000046, maybe to many 0's. but mine will be heading to get modded next week...(monday)....(may 23rd). so are they still avalible in USA or no? i know the next shipment is due to leave today, but cant see them being here by saturday! by the way bro!!...HAPPY BIRTHDAY MY FREIND!!!!!
so,yes they are all sold out in the usa
#1444
SWEET!!!!! if moto has another one i will buy it right now! but i think he is in bed for the night...LOL, smart man!
#1449
I have found when the motor is right on song with a good steady idle, the idle gap is tiny - nowhere near 1mm and probably less than .7mm going on the trusty eyecrometer (with glasses fitted)
#1450
Just keep tweaking the idle gap in a little at a time until it comes in and sits with a steady idle Matt. Then if needed richen the bottom end a little to compensate. You may have to juggle these two to get the idle speed you want. The revs dropping is 90% going to be the idle gap is just a smidge too wide.
#1451
Thanks,
#1452
Remove your filter and check carb barrel at 1mm opening. First, best try to raise your idle to start engine and keep it running, run a couple of straights and should hit at least 190f temp then tune your idle lowest posible before leaning 1/8 on lsn.
#1453
To reduce the idle gap turn the idle screw anti-clockwise. This will allow the throttle slide to close more and reduce the idle air gap. It will also bring the low speed needle (which is attached to the throttle slide) into the spray bar more, thus slightly leaning the bottom end. This is why you may need to richen the bottom end a little to compensate.
The idle gap / low speed needle relationship is a delicate balance. Everytime you change the idle gap you effectively change the bottom end tune, so it is a bit of a juggle to get it just right and the two settings in harmony with each other. I reckon 95% of all tuning glitches occur around the relationship between these two.
#1454
If it's doing what Matt was describing then the idle gap is probably to wide.
hi guys, thanks for the info.. recently ran the GX2 and it has a very decent idle and running was good. Will check the idle gap, which should be about .7 to 1mm.... thanks.
Jojo
#1455
Go to the GO Racing NZ Ltd web site at http://www.go-racing.co.nz
Go to the Tech Tips page from the left hand side menu bar. Scroll down past the run-in section to the tuning section. There you will find what I am talking about. It's a bit long winded to go into on here at this time of night where I am
Follow this procedure for tuning from step one right through and see how you go.
1Likes
