Like Tree1Likes
Go Engine USA 2011 Thread
Old 05-15-2011 | 06:53 PM
  #1471
deadmancourt's Avatar
Originally Posted by inferno13
thanks grizz, ill give it a try tuesday, smoked my losi starter box and will have the ofna box tuesday
You must get the motor up to atleast 200F....I have broke in 3 gx5r motors and 1 gxii on the same losi box and same rubber wheel..10 tanks down on my HO and I'm just barely pulling full throttle....she's ready for some practice on the track....its GO time!
deadmancourt is offline
Old 05-15-2011 | 06:56 PM
  #1472
Suspended
i heat it up to 220 every time, its not the engines, its the cheap starter box motors i have been useing. i could afford better ones if i dint spend so much on GO ENGINES....
inferno13 is offline
Old 05-15-2011 | 07:00 PM
  #1473
Suspended
wanna buy a losi box with 2 smoked titan 12t motors
Old 05-15-2011 | 08:30 PM
  #1474
22Racer's Avatar
Ran the GxII Ho today, it was on a tighter track but it really ran nice. Kendall took it for a few laps also, I was impressed with the power, nice motor.
Rex
22Racer is offline
Old 05-15-2011 | 08:31 PM
  #1475
grizz1's Avatar
Spend a hundy on a Competition Heat pre heater, then you won't have to worry about your starter boxes. Will heat the motors much more effectively than anything else. Heat up to 180 F only, but it will heat right through in 8 - 10 min. Your 220 on the outside now is probably only 140 in the middle of the block, PRS area. 180 F on the Comp Heat will be 180 right through the motor.
I always used a heat gun because I didn't know any other way, but now I have been enlightened
grizz1 is offline
Old 05-15-2011 | 08:32 PM
  #1476
MassiveMods's Avatar
Originally Posted by grizz1
Yeah - I would set the idle gap by using the pinch test when the motor is cold. This is a very accurate way to set the gap on a motor by motor basis, depending on what set up you have.
Go to the GO Racing NZ Ltd web site at http://www.go-racing.co.nz
Go to the Tech Tips page from the left hand side menu bar. Scroll down past the run-in section to the tuning section. There you will find what I am talking about. It's a bit long winded to go into on here at this time of night where I am
Follow this procedure for tuning from step one right through and see how you go.
Hey Grizz the 7 second pinch tune is now out the window. The new LSN taper and length has put it out from the original by a mile ....
Bup Booow ... probably why the guys in the US are having probs with the tune..
M
MassiveMods is offline
Old 05-15-2011 | 08:35 PM
  #1477
22Racer's Avatar
I have been using and selling the Competition heat also, just love them. I use the 110v, just plug it in and its ready to go. (is your voltage different down there Grizz?) When I break in a motor I will leave the Comp heat on it to soak the motor and then warm it up a bit more with a heat gun.
Rex
22Racer is offline
Old 05-15-2011 | 08:37 PM
  #1478
Suspended
M
never cared for that tip! not accurate in any motor, all depends on where you pinch line to get 7 seconds, not accurate at all, fuel line, spot where pinched, fuel, have have a effect on pinch test
Old 05-15-2011 | 08:58 PM
  #1479
Leo V.'s Avatar
Default ??
I've had 2 sets of 7-port P/S with the same problem. the opening of the hole of the piston where the wrist pin goes into is chipping (looks like the edge of the hole is eroding and flaking off), exposing the clip. Eventually the clip comes off, gouging up and down the side of the piston.
Leo V. is offline
Old 05-15-2011 | 09:00 PM
  #1480
grizz1's Avatar
Rex
Hi Rex,
Yes - we have 230v AC power here, so that's why I went for the 12v unit for customers here. I am also looking at a mains powered adjustable supply (Muchmore Mini) for workshop break-in duty. These auto adjust to input voltage from 110 up to 240v, and is adjustable down to 11.5 volts on the output - ideal for the 12v Duece unit.
grizz1 is offline
Old 05-15-2011 | 09:17 PM
  #1481
grizz1's Avatar
If you hated it that much why didn't you speak up sooner ? Seemed to work for most of the guys on here.
It tuned our team motors here to wins and podiums in every national event last year, so it must have worked a treat somewhere along the line.
I shall revise the web page now I stand corrected on the new motors. Knowledge is power
grizz1 is offline
Old 05-15-2011 | 09:30 PM
  #1482
MAGPIE-121's Avatar
+1, been using the same set up for 6 months now at the track & at home & what a money saver it is in fuel, tyres & wear n tear on me motors & buggy/truggy with no warm-up laps required.
MAGPIE-121 is offline
Old 05-15-2011 | 09:33 PM
  #1483
motomatt's Avatar
Comp Heat here for about 15 months now. Greatest invention for nitro engines since.................well, since nitro engines.
motomatt is offline
Old 05-15-2011 | 09:48 PM
  #1484
grizz1's Avatar
Hi Leo - now please don't take this the wrong way, but ovaling and damage to the wrist pin hole in the piston can be the result of a short, hard (ie cold temperature) break in.
The wrist pin takes a hammering if the motor is broken-in not being pre heated, and run at low temperatures. This can quite often cause the damage you are refering to, or certainly weaken that area and make it susceptible to early wear.
grizz1 is offline
Old 05-15-2011 | 09:56 PM
  #1485
M
my break in on my GXII went perfect.10 tanks down, only 3/4 of a gallon left before I unleash the beast
