Like Tree1Likes
Go Engine USA 2011 Thread
Old 11-28-2011 | 08:17 PM
  #2191
Suspended
Originally Posted by voodoopapa
cool thanks. The engine (GX5R) factory settings are HSN (Flush) and LSN (Flush). Are these the correct settings for run in?
Also I'm going to run this in my Hara D8. How can you tame the bottom so it's manageable in the buggy.
for the first race or 2, set your throttle so it only opens about 3/4 at wide open. this will help you get use to the engine and probably give you better lap time and runtime than if you open it up 100%, also like stated above, a softer clutch will engage a little quicker and you will have less wheel spin
inferno13 is offline
Old 11-29-2011 | 05:19 AM
  #2192
asaraneta's Avatar
Front 7 x 19 x 6
We only run steel in the front due to dust and dirt being forced up into the bearing under the flywheel. Dust and dirt are the mortal enemies of ceramic bearings. Plus front ceramics don't like the shock loading from the starter box when cold. The front bearing is small in comparison, so you are not gaining a huge amount by going to ceramic here.
Rear 14 x 25.4 x 6
Run either stock or ceramic here. We have been using the Answer Si3N4 silicone nitride ceramics and find them excellent and very long lasting. The Avid ceramics are also a very good bearing. Both have good ABEC ratings.[/QUOTE]
Thanks for the reply, appreciate it.
asaraneta is offline
Old 11-29-2011 | 11:31 AM
  #2193
Originally Posted by grizz1
Front 7 x 19 x 6
Rear 14 x 25.4 x 6
Great insight, thx for taking the time!
Question on the GXII, is anyone having to shave down the collet to get enough crank sticking out of the clutchbell with Losi clutch? Or is there a shorter collet available somewhere which does not need to be shaved?
AZTman is offline
Old 11-29-2011 | 11:39 AM
  #2194
Suspended
you need a losi collet, they are shorter than the rest
  #2195
losi_racer's Avatar
Travis you must use the losi collet on losi clutch . Part number is losa9376 , it says for losi 1/10th gas but it the same used for 1/8th
losi_racer is offline
Old 11-29-2011 | 11:45 AM
  #2196
grizz1's Avatar
Not sure on the Losi set up, but if the end of the crank is a little short of the end of the bell, use one of the OFNA clutch bearing retainers with the built in extender. This effectively gives you about 1 or 2 mm more of crankshaft length.
http://www.amainhobbies.com/product_...Bells-Shim-Kit
If you enlargen the picture, you will see the lip on the retainer that gives you the extra length. Hope this works for you
Oops - looks like the boys have it sorted while I was away finding the link. Problem solved
grizz1 is offline
Old 11-29-2011 | 12:21 PM
  #2197
grizz1's Avatar
Originally Posted by curacing2
Thanks Shane, I'll leave it as it is when i fit the new head back on, fingercrossed the weather doesn't effect the weekend too much, may have to do well saturday incase $h!t happens sunday alway a fun trip away regardless of how the racing goes thursdays going to be a big day! practice into the night, pig on the spit and a band! we'll have to stop at the wholesalers on the way being that far out in the sticks.
looking on the map its a long way down south,I wonder will there be any banjo player in the band
GX 7R is an awesome motor, i still have a good one running and love the power in a buggy, can't wait to see what the GXII 7 HO will be like
He he yeah - If he is a 12 fingered banjo player then we know we are in trouble
Weather looks good until Sunday, so qualifying will be all important
Was in contact with Simon at GO the other night, and no immediate plans for the 7HO. They are working on other projects for early next year at present.
Good luck Flanno - give em hell mate
grizz1 is offline
Old 11-29-2011 | 01:08 PM
  #2198
Flanno's Avatar
Cheers Shane, I'll do my best and have fun too
Flanno is offline
Old 11-29-2011 | 02:29 PM
  #2199
curacing2's Avatar
Will be interesting to see what they come up with next year
It would be nice to have something new to offer next year when we can run bigger motors in truggy, a .23 or .25 HO 5 port would be a good option next winter
curacing2 is offline
Old 12-03-2011 | 09:08 AM
  #2200
sriley's Avatar
Will the GXII sleeve and piston work in a GX-5R?
sriley is offline
Old 12-03-2011 | 09:54 AM
  #2201
Privateer_45's Avatar
Privateer_45 is offline
Old 12-03-2011 | 10:58 AM
  #2202
Suspended
Originally Posted by Privateer_45
sure will. i have a brand new go gx II for sale. brand new 110.00.
pm sent
Old 12-03-2011 | 04:13 PM
  #2203
MAGPIE-121's Avatar
i think the top of the sleeve is different so we can't mix & match
hope i'm wrong, but i don't think so
MAGPIE-121 is offline
Old 12-03-2011 | 08:01 PM
  #2204
deadmancourt's Avatar
it will fit in a gx case...i installed a gxii p/s/r in my buddies gx5r case and has been dialed for like 5 months
deadmancourt is offline
Old 12-03-2011 | 09:57 PM
  #2205
motomatt's Avatar
When the GXII5R was released, I was informed that all GXII parts are backwards compatible.
I do believe that if you want to put the finned head button on, you will need to use the GXII heatsink also.
Hey Rob! Long time!
Where have you been?
Did you get a 90 day stint with no work release or something like that?
(J/K J/K J/K)
It's been like three months since you dropped in here.
Does Cali have an off-season?
motomatt is offline
