Like Tree1Likes
Go Engine USA 2011 Thread
Old 02-11-2011 | 10:02 PM
  #511
Default fuel
I have a few types of fuel around, but I have loved SideWinder for a while. Does anyone have a lot of experience with the new purple stuff? It is suppsed to get a little more runtime, but has less oil content. Any risk?
AZTman is offline
Old 02-11-2011 | 10:46 PM
  #512
deadmancourt's Avatar
honestly, lately i have not heard good news about that fuel...but thats just what i heard...i have never ran it myself...sorry
deadmancourt is offline
Old 02-14-2011 | 06:12 AM
  #513
psychoracing's Avatar
is there going to be any changes done to the .25 & .28 and if so when will it be out ,i run them in my oval car..
psychoracing is offline
Old 02-14-2011 | 07:31 AM
  #514
Ruune's Avatar
Eventually, there will be a replacement for the current .25 pro. I don't know about the .28. However, youll get more power and mileage out of the new .21s.
Ruune is offline
Old 02-14-2011 | 10:44 AM
  #515
not much to report...Well i qualified 7th in the Expert Truggy A-main for the Grassroots Racing Series @ Palm Desert Raceway on saturday....was doing great for the first 3 mins and i caught a spike on a pipe or something and it over extended my right front shock and yanked out the shock end, so i had to run the rest of the race with only 1 shock....i ended up getting 5th(last)...there was 176 entries and my race was last(20 min main) and it didnt start till midnight...so there were people that couldnt hang and just went home, instead of racing the main....lucky for me its a points series, and i still have 7 more chances to get up in the points
Old 02-14-2011 | 12:50 PM
  #516
motomatt's Avatar
I got a 2nd place finish for the 3rd straight time.....................in stock short course oval carpet . GMWAS
If it doesn't have a piston, it's just not the same.
Gawd, I wish outdoor season would get here.
motomatt is offline
Old 02-14-2011 | 04:41 PM
  #517
22Racer's Avatar
I hear ya Matt, I am ready to burn some nitro. Are you guy's gonna come to the motodome in March? (Fhf race)
Rex
22Racer is offline
Old 02-14-2011 | 07:32 PM
  #518
rider313's Avatar
I recommend you should come on over Matt. Its a good time. I cant wait.
rider313 is offline
Old 02-14-2011 | 08:31 PM
  #519
motomatt's Avatar
I'm sure it's a great time.
A couple of the guys are brainstorming about it.
It's about a 7 hour drive for me.
("pit stops" every 90 mins.)
motomatt is offline
Old 02-14-2011 | 11:50 PM
  #520
Default Short vs Long LSN
My last 5port had the long LSN, the GX5R comes with the short LSN... until the 2011 GXII's I guess. Should I use the long LSN from my old 5port? Should I buy a new one? Or use the short LSN in the motor?
Thanks for the help guys!
Travis
AZTman is offline
Old 02-15-2011 | 12:24 AM
  #521
grizz1's Avatar
Travis
It doesn't really matter. The long needle gives a slightly smoother powerband, and maybe a little better economy. It's easy to swap them over.
Just remember the LSN sits about the same, say 1.5 - 1.75 turns in whether you are running short or long needle, but the HSN settings are quite different for the two LSN needles -
Short LSN needle - HSN = .5 to .75 "TURNS" in from flush.
Long LSN needle - HSN = 1 to 2 "HOURS" only in from flush.
If you get lean bog at or below half a tank with the long LSN fitted, then richen the HSN 1 hour at a time until the lean bog goes.
See this tuning guide for more details on the long needle tuning -
http//:www.go-racing.vpweb.co.nz/Tech-Tips.html
grizz1 is offline
Old 02-15-2011 | 07:33 AM
  #522
the .21 will not work on a high bite track in the outlaw class, we run the .25, .28 in it in oval .. i run the .21 in my buggy and its awsome....
Old 02-15-2011 | 08:48 AM
  #523
Ruune's Avatar
have you tried the GX-5R or GX-3R with a larger spur gear, or smaller pinion?
Ruune is offline
Old 02-15-2011 | 10:25 AM
  #524
JGray's Avatar
I run the GX-7R with a 2072 pipe in my late model and have power to spare. That is running against 25/28/32's with no problems. Tim McNutt used my 7port in the outlaw class at the Chili Bowl and had more power than he needed. I guess it all depends on the size track you race on.
JGray is offline
Old 02-15-2011 | 11:26 AM
  #525
Put a half gallon on my new GX-5R yesterday breaking it in. The engine already has scary power LOL. Thanks to Ruune for helping me out when I finally got to put it on the track.
Anybody here use the 6.5mm restrictor? Thoughts?
nik77356 is offline
