Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 12-14-2013 | 12:48 PM
  #1291
Tyson72's Avatar
Originally Posted by frozencone
I've had this similar issue, but my case cracked roughly towards the end of gallon number 3 almost 4. The engine performs really well I like how smooth it is, but materials seriously needs improving.
A friend of mine was having problems with his GTR last wknd. I took a look at the chassis, the first thing I noticed was a lot of dirt stuck to chassis around the engine area. I asked him Wat that was he said he spilt a lot of fuel while refueling his car.
But it seemed a bit strange to have such a mess like that.
Anyway I replaced the plug, had a go at tuning, but nothing was working. It was just dead off the bottom and kept flaming out. I knew it wasn't good!
So the following week he came around after work so we could take a closer look. Turns out the bottom of the block had a long crack right down the centre and also around near the back plate. He told me after he had a big crash it just started running really badly. He is still very new to the hobby and is crashing a lot as he learns to drive, so I would say that last crash was the final blow.
I drove his car a few months before and got it to race tune for him. I liked the engine it was nice to drive, very smooth power, just lacking some durability..
Tyson72 is offline
Old 05-08-2014 | 10:55 AM
  #1292
alexzone007's Avatar
Default gtr plus
hi arrow owners i am thinking of buying a arrow gtr plus 5 port the 5 ports i used to have o.s vspecs and mugen ninja jxbo1 my favorite I HAVE NOW THE O.S 21XZ-B but needs now bearings piston and sleeve so i was thinking in buying the arrow for the moment and test it but not sure about the arrow , heard the new arrow gtr plus have a stronger crank now are this engines strong or just another marketing engine that gives problems on the 3rd tank and need to buy a o.s carb and add it ?? i would like to know more about the engine the price for 200 is not bad for a ninja clone but are they good the carb is good crank are they reliable ? or need to buy O.S PARTS and add THEM to be good IF THAT THE CARE I STAY O.S ?? thank you people
alexzone007 is offline
Old 05-08-2014 | 12:55 PM
  #1293
I used an Arrow 3 ports for 9 gallons until the rod broke. Until then, the engine was perfect. Just replaced a front bearing on fifth gallon. Considering the price, was the best engine I ever had!
Consider the needles positions discussed on this topic, not the positions of the manual.
patrickgarcia is offline
Old 05-08-2014 | 07:07 PM
  #1294
Originally Posted by Dob
Almost done with break in on my GTR plus. Thing is a beast. Just want to make sure I got this mid range setting down. If I back it out 2 turns from flush so that its pointed at 2 o'clock, isn't there 50% chance that its actually pointed at 8 o'clock? I may be over thinking this but since the screw head "points in two directions" how do I know its pointed at 2 and not 8?
The instructions i got with my Arrow said the midrange needle is supposed to be flush with carb body, is this correct or should i be doing something different?
rcdan is offline
Old 05-08-2014 | 07:09 PM
  #1295
Originally Posted by VPProUSA
Mid range - 2 turns out from flush at 2 oclock
Top 1.5-2.5 turns out from all the way in
Bottom 1/2-1 turn in from flush
Nevermind, found my answer.
rcdan is offline
Old 07-04-2014 | 09:14 AM
  #1296
cczjordan's Avatar
Is the cera engine same to gtr plus?
cczjordan is offline
Old 07-05-2014 | 06:40 AM
  #1297
kaptain crash's Avatar
no...maybe from the same factory but a different engine.
kaptain crash is offline
Old 07-05-2014 | 08:54 AM
  #1298
I think Cera is GO Engine.
Tigergutt is offline
Old 07-05-2014 | 01:36 PM
  #1299
cczjordan's Avatar
Arrow was go base?
Old 07-05-2014 | 02:21 PM
  #1300
VPProUSA's Avatar
Arrow was go base?
Arrow might be made at the Go Factory but they are not the same as Go Engines. There are only a few factories in Taiwan, so many different brands are made in the same place.
VPProUSA is offline
Old 07-05-2014 | 07:23 PM
  #1301
cczjordan's Avatar
Thanks for the clarification
Old 07-29-2014 | 06:26 PM
  #1302
cczjordan's Avatar
Can anyone help me with arrow gtr plus 3 needles setting for break-in. Fuel rapicorn 25/9 fully synthetic with adding of 2oz byron loop booster? Thanks in advance
Old 07-30-2014 | 07:26 AM
  #1303
VPProUSA's Avatar
For break in the settings are not important, just set them so it starts and idles good and keep the temps between 200-240'F.
VPProUSA is offline
Old 07-30-2014 | 11:19 PM
  #1304
cczjordan's Avatar
Ok thanks
Old 07-31-2014 | 06:42 AM
  #1305
cczjordan's Avatar
Did 6 tanks n try full throttle with extremely rich HSN, BUT the sound of starving fuel/misfiring. Is this carb tune like 2 needle carb? Or i need to tune the mid needle?
