Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 07-31-2014 | 06:47 AM
  #1306
BillyT.'s Avatar
Set mid and forget it.
BillyT. is offline
Old 07-31-2014 | 07:22 AM
  #1307
VPProUSA's Avatar
Originally Posted by cczjordan
Did 6 tanks n try full throttle with extremely rich HSN, BUT the sound of starving fuel/misfiring. Is this carb tune like 2 needle carb? Or i need to tune the mid needle?
Set the mid to 2 turns out from flush at 2 oclock and leave it there. Then it will adjust like a 2 needle carb.
VPProUSA is offline
Old 07-31-2014 | 08:46 AM
  #1308
cczjordan's Avatar
Guess is over rich hsn o weak plug... Thanks
cczjordan is offline
Old 08-01-2014 | 02:40 AM
  #1309
cczjordan's Avatar
Having serious problem to fine tune, when WOT, feel like starving for fuel but still extreme rich hsn. Change 2 new plug but same problem. 10th tanks...
Hsn-3 turn out from full close
Msn-2 turn out from flush 2pm
Lsn-1.25 turn in from flush
Plz assist
Old 08-01-2014 | 03:03 AM
  #1310
Have you fiddled with your idle gap? Make sure the idle gap is small - like 1mm or less.. As you close the idle gap, you generally need to lean the LSN to raise the idle back up - and vice versa.. I'm not a tuning expert, but often I find richening the LSN helps get things in the ballpark if a tune is playing hard to find... (but that is sometimes also compensating for a too-big idle gap..) The trick is finding the balance between the idle gap and the LSN - the HSN is simple..
All I've ever heard about MSN's is ... don't mess with them.
Herrsavage is offline
Old 08-01-2014 | 04:19 AM
  #1311
cczjordan's Avatar
Yes with msn. For idle gap n lsn is correct. I just need expert opinion with 3 needles carb. Cant seem to make it dial
Old 08-01-2014 | 08:37 AM
  #1312
cczjordan's Avatar
I did some reading, i think my tune got problem in the transition from mid to top end if the plug happen to be good. Should i lean the mid needle .5turn n richen lsn .5turn. I think just leave the hsn rich for safety. Any opinions? Thanks in advance
Old 08-01-2014 | 09:37 AM
  #1313
VPProUSA's Avatar
I would lean the top to 1.5 turns out and see what is does on a full throttle run. If it cuts out, then richen it and re-test. The bottom end is mainly for idle speed. If it won't clear out from a 10 second idle, then lean the bottom also.
The pipe, plug, and fuel will change what the top and bottom needles need to be set at.
VPProUSA is offline
Old 08-01-2014 | 10:54 AM
  #1314
merdith6's Avatar
Default fuel
It might be your fuel. You said you added 2 ounces of castor oil. That is twice what I would add although I am not familiar with the brand you mentioned. Just an idea.
merdith6 is offline
Old 08-01-2014 | 05:19 PM
  #1315
cczjordan's Avatar
Old 08-02-2014 | 02:20 AM
  #1316
cczjordan's Avatar
Replace tank
Old 08-11-2014 | 02:44 AM
  #1317
cczjordan's Avatar
I run 5port n 2103 arrow pipe. Any recommendation for better power band n fuel efficiency. From this forum os 2060 not suitable on 5port.
Old 08-11-2014 | 04:21 PM
  #1318
i have one of the gen 1 3 port engines and i hated the carby on it. was difficult to tune and seals were crap. ever since i put the 2 needle carb from the MG66 on it it has been awesome!
brendon.matt is offline
Old 08-11-2014 | 04:27 PM
  #1319
cczjordan's Avatar
From what i learnt in this forum. Is a good carb. Get the msn set then dont tune it. It it tune like 2 needle
Old 08-11-2014 | 04:34 PM
  #1320
VPProUSA's Avatar
Yes the carb is good now, you just have to have the mid range 2 turns out from flush at 2 o'clock. Then it tunes just like an OS carb.
The seals and the carb insulator have all been improved since the original version also.
VPProUSA is offline
